Look>Spark plug removal
Old Apr 8, 2006 | 06:13 AM
J-Dizzle's Avatar
Still Addicted to Boost
Default Look>Spark plug removal
took these out last night, i think the oringinals from the swap , very nasty! hard to look at andthink my motor was running with thesze shits, well replacing them with the same NGK iridiums> anybody got any info on these plugs, fuggin $7 a piece ...and i know it obviuos but what will i expect after changing these? thanks.....i think im missing something that changing spark plugs do
jason
Don't Text And Drive
Old Apr 8, 2006 | 06:28 AM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Iridiums are a good idea for forced induction...if you like pissing away money on plugs that really dont do any better than anything else and get too hot under boost.
Get the OEM plugs. Theres a reason Toyota spent money researching and came up with the stock plug type. These were high end cars back in the day...if they had iridium plugs back then and found them to work, they'd use them
The white fuzz on the bottom of the plugs mean that it is the wrong heat range also btw.
ASE: Brakes
Old Apr 8, 2006 | 06:47 AM
J-Dizzle's Avatar
i see...interesting.....so which ones should i use?
Old Apr 8, 2006 | 06:50 AM
J-Dizzle's Avatar
nevermind that i just ordered them from toyota $12 a piece
Old Apr 8, 2006 | 09:26 AM
Woah lol probably didnt have to spend that much...I've never spent more than $10 on all of my plugs together
Just find out what the stock type of plugs are for the 1G and get those...usually Denso/Bosch Platinums with an equivilent cross reference
ASE: Brakes
Old Apr 8, 2006 | 09:32 AM
J-Dizzle's Avatar
well i went the Oem toyota route...BIG DIFFERENCE!!!quiter and a shit oode quicker when hitting boost..came to $80 total ..oh well solves the problem
Old Apr 8, 2006 | 09:39 AM
Glad I could help though! I told you the Iridiums blew
ASE: Brakes
Old Apr 8, 2006 | 08:53 PM
J-Dizzle's Avatar
yea....i did alot of research also ..and found pretty much everyone saying they hate boost for some reason
Old Apr 9, 2006 | 11:21 AM
Reign_Maker's Avatar
Boost addict...
YIKES! O..o... orion... Iridium plugs are FANTASTIC plugs to go with, especially for high boost applications... Copper are great too, but you'll change them more than the iridium... Platinum are worthless in a boosted car, I had so much chatter with them, ping and misses... Iridium fixed that quickly... I paid $6 a piece for my NGKs at O'Rielys... I'll be breaking my motor in on coppers, but will be switching to Ir plugs after the break in... Anyway, Im glad you got your car running well... Im really glad you got those nasty plugs out... lol... YIKES! It looks like they were sittin in the open for a while...
7MGTE... Built bottom... Built head... Built tranny... Big turbo...
Lots of fuel... Almost 2 years in the making...
Old Apr 9, 2006 | 05:18 PM
Pretty certain its quite the opposite...if a stock boosted car uses platinums, there may be a reason IMO. I've heard Iridiums just heat up too much under boost.
With your platinums, did you do the "for every 100HP over stock, add 1 heat range and .001" closer gap?"
ASE: Brakes
