1UZ-FE Gearbox?
I recently did a 1UZ-FE swap into a Nissan 240SX and it turned out very easy. I make adapter plates for just about any transmission you want to run. In this photo I have an SR20DET transmission bolted up to it. I've successfully mated together the 350Z 6-speed and the R154 5-speed all to the 1UZ-FE. I am currently working on mating together a 4-speed Dog-box for clutch-less shifting and high rev applications. the cheapiest 6-speed on the market today is the 350Z 6-speed, you can find them on Ebay for 300$ and the adapter plate that I make, makes this combo a direct bolt application.
if you guys have any questions don't hesitate to ask
my email is BrettWcollins@gmail.com
here is a video of the car at a local drift event about a month ago.
YouTube - floridaracing's Channel
how much are your adapters for the 6 -speed? im about to put a clutch in my 1uz supra but if i could go with the 350z tranny and get a cheaper clutch then it may be worth it to send the extra cash. because it going to cost me 570 to replace the clutch in my w58 and it has a custom mr2 set up. so i got to get a purty stout clutch set up to handle the power.
Bought Not Broken!!!
member #3
member #3
Sweet to see another 1uz in another application instead of the 5000 threads for a jz setup. What engine management are you running? Stock ecu? I have the w58 manual trans adapted to my UZ. Do you have that odd miss when idling? I still haven't figured out that issue with mine.
more info on 350z trans
Branden Berger
352-789-0006
86.5 toyota supra- 1jz never to be finished
01 mitsu eclipse v6 5mt chick car daily
98 honda accord ex- h22 swapped daily driver
Branden Berger
352-789-0006
I sell the adaptor plates for cheaper! 215$ I also carry the modified flywheels.
www.1uzfeswapkit.com
awesome i will be buying one off you soon
Branden Berger
352-789-0006
Branden Berger
352-789-0006
OK email me if you're serious about the 350Z trans adapter plate, I'm getting ready to throw a kit on ebay, because I need extra money so let me know.
350Z tranny adapter is really easy, I have the throwout bearing adapter and pilot bearing adapters already made.
Brettwcollins@gmail.com
or if you wanna come to the house and see the swap in person, and go for a ride email me as well.
why are the 350z transmissions so cheap? who are they made by? is it a borq-warner piece? or gettrag? and what is the tq rating of it?
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
