i need help
Originally Posted by Troux
Buy a perfectly running MKIII. Those make nice projects.
ASE: Brakes
ASE: Brakes
mk1.5 sw11 conversion for an aw11 w/ a 4age to a 3sgte sw20 MR2 motor
slammed on tien full coilovers, big brake conversion, 17" rims(front) 18"rims(really, really wide i.e. 11" or so(rear) , poly-urithane bushings and other stiff stuff....(i could go on for ever)
or something like that
if tuned right you will have a ~275rwhp and dominate the streets
the car with blown or bad 4age motor can be found for about 300-500 bones and the motor and swap can be done for about $3000
add another 2500 in various up grades
and there you have a 10 sec rwd for about 6g's
SOLDfor sale::::ae86 sr5 converted to twin cam carburated
webers/ headers/ msd/ 4puck unsprung clutch/ 10000rpm tach
4 point harness/ custom exhaust/ custom camsSOLD
aw11 mr2 is a great project and fun as hell to drive. you have a lot of engine choices too!
Part of:
Wangan Midnight Maximum Tune 2 sedan expert.
APXRO: JZX100 Chaser "Odaiba Romance" 815HP/DG B1 2 overhauls. secret weapon
PM!: UCF10 Celsior "Jealousy" 810HP/DG B3 0 overhauls. vs battle car
Part of:
Just the rims and suspension you stated before are more than 2500 in mods.
The only 1.5 I know of and have ridden in quite a bit, is a 12 second car with around 295whp and runs 12's. 10's are a bit further away than it seems. I would also figure around 10-15 K to achieve the results you need with all the mods you stated above.
I'll call Matt Armstrong and see what his total was for his 1.5.
I dont feel like a sig today.
