mr2 first gen engine swap question
Old Jun 28, 2005 | 12:00 PM
NROD17's Avatar
Default mr2 first gen engine swap question
has anyone tried using the non supercharged bottom end with the super charged top - planning on using a large metal head gasket to help equal compression but still think its questionable. any ideas or imput
thanks
Old Jun 28, 2005 | 01:59 PM
gotime242's Avatar
Use a Northstar V8 engine from a cadilac. That would make you move well...
Old Jun 28, 2005 | 02:10 PM
Jap's Avatar
Jap
VTEC Out
The supercahrged Head theoretically would make less power . Unless you haev an AE101 Smallport GZE head .
If your usign a US spec GZE out of an MR2 why would you use a GZE head ? It has less lift and duration cams but is otherwise the EXACT same head .
Unless you have a smallport head , use the N/A Bluetop head ....
Hondata saves lives
Old Jun 28, 2005 | 06:19 PM
hachibill's Avatar
yea sweet lemonade
DO NOT USE THE N/A bottom end, it will work ,but not be as reliable as the GZE bottom end. toyota changed things for a reason.
Old Jun 29, 2005 | 05:16 PM
toyotajoe1980's Avatar
drifting in the rain
n/a head and gze butt backed by a turbo from a dsm and you will have a car that is to fast for its own good but thats my oppinion
SOLDfor sale::::ae86 sr5 converted to twin cam carburated
webers/ headers/ msd/ 4puck unsprung clutch/ 10000rpm tach
4 point harness/ custom exhaust/ custom camsSOLD
