5e help
Old Mar 22, 2005 | 12:27 PM
boosted_seo's Avatar
FWD SUCKS!
Default 5e help
well i sent off my hybrid 5efhe/4efte, to get lower compression pistons put in, and i dropped my old 5e in, i've been driving her for over a week now, and today, i was @ a light and she started knocking. but she will only knock @ 2000 rpm's, not before, and stops knocking after 3500? what can it be? i dont think it's a main or rod bearing, cause than it would be knocking @ all RPM ranges. Help Please, i need to keep this motor up and running for the next 2 months @ least
My Efffing MYSPACE
Originally Posted by boosted_seo
A car isn't fast unless the check engine light is on . . .
one_fast_ek: Why is it always the ugly primered hatches are always the fast ones . . . ?
(\___/)
(")__(") This is Bunny. Copy and paste him into your signature to help him gain world domination.
Old Mar 22, 2005 | 08:31 PM
FWD SUCKS!
anyone? help, please!
My Efffing MYSPACE
(\___/)
Old Mar 24, 2005 | 01:18 AM
ToyDoctor's Avatar
The knock is most likely a rod. If the noise is at about 2k rpms, and you can manipulate the noise with light throttle inputs then it's definately a rod. Also see if you can eliminate or change the noise by killing one injector at a time. I would drop the pan, pull the bad bearing, polish the crank with emery cloth, install a new correctly select fit sized bearing with a plastigage. If the oil clearance is too high, check to see if you can install a bearing with a higher select fit size.
Old Mar 29, 2005 | 04:49 PM
FWD SUCKS!
ok, well, i'm looking for either a 5e long block or a 4efte longblock localy(more so on the 4e), can anyone help me?
My Efffing MYSPACE
(\___/)
Old Mar 29, 2005 | 07:58 PM
bildo6's Avatar
nice slow 40mpg
byp in miami for the 4e block. only place i can think of to get one somewhat locally
Old Mar 30, 2005 | 06:49 PM
barry bledsoe's Avatar
The lost pony
you can also tell wich one it is by pulling plug wires 1 at a time if that is easier
