Aaaahhhhhh
I need to know what i need besides the headgasket to do the headgasket job on my 1988 toyota supra turbo?? and i need to know what would be a good bpu for the car
God giveth and I taketh away
headgasket , front timing cover gasket and i cant think of anything elso oh eah an engone lift if you dont take the intake manifold off and also a exhaust manifold gasket.
93 Touring RX7 LS6 "Bolt Ons" -Toy
92 Talon AWD Turbo -daily/snow car
Team Fail Racing
Boredom owns me.
its like negative penguin outside this is bullshit.
-Angela
Team Fail Racing
Boredom owns me.
-Angela
get ARP head studs torque them to at least 85ft/lbs
get a cometic headgasket
and as far as bpu a divorce downpipe yields good gains
Originally hollered by PoppaSmurf: Hey!!! Driver!!! Your Face!!!
TheSh0w50h: I am teh badass assed roll racer evar, I eat mkIV's for lunch.
Originally posted by JuicedSS262
No longer have the stomach for clubbing baby seals.
Those sad eye's got to me.
haha wow...
ok let me see if i can get you a list to do it RIGHT (read: never have to do it again):
Headgasket(preferably Cometic)
Headgakset SET (will give you all the top end gaskets)
thermostat and O-ring
Oil
Coolant
Machined Head
Block checked for warpage(if warped it needs to be machined...if not you can clean it really well and lap it)
Torque Wrench
Either NEW HEADBOLTS from toyota...OR PREFERRED ARP STUDS
i think thats all you really need... but while taking it apart and doing things youre bound to break some vacuum hoses which you should replace anyways....among a few other small things...
if you are 100% new to turning a wrench...it will be a project...hit me up on aim at lamplitersniper and ill help you out...and maybe if you are near ill help you do it...
as for "BPU" technically thats a mk4 term but hey why not lol..."BPU" on a mk3 would be intake, exhaust, boost controller thats about it... that will put you around the 300hp mark depending upon exhaust and psi you will be running.
HTH
Oil
Coolant
Machined Head
Torque Wrench
HTH
When you use a torque wrench if you dont have a superb one rent one from autozone. as far as replacing the HGS every 20k miles depends on how u replace it the first time
oh Jayson you forgot the copper gasket spray
change out the belt tensioner, and replace the timing belt while you're in there.
sold>> Single gt3582r powered 2jzgte
Ellis Autoworkz
Smoke 2004 LE
Crew Cab *Big Tow Package *4x2
Ellis Autoworkz
Smoke 2004 LE
and as for the timing belt and tensioner...you could..but frankly IMO enjoy the fact that its a non interference engine and dont worry about the timing belt shit until it breaks
if you're going to pull the engine do everything, belt seals, tensioner... everything just for insurance, and the fact you dont have to do it again
Ellis Autoworkz
Smoke 2004 LE
Ellis Autoworkz
Smoke 2004 LE
