1jzgtte or 2jzgtte????
well im wanting to get some specs on bothe engine's for a posible swap
some people are saying go with the 1jzgtte and some are saying 2jzgtte Im having problems finding HP info and tracking down front clip's as well....
but please list me up whitch you prefer and why, to me it make's more sence to do the 2j with the 3.0 displacement but other's are saying the 1j with the 2.5 disspalcement and i was just woundering why????
so any info would be great.
thanks much
art
thanks much
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
www.rccustomz.com
Guest
Posts: n/a
well im still alittle halfed between the 2 engine's Im looking to put one in a 95-97 sc300 so i would like a pretty strait forword swap in and just basic mods such as a single turbo change out and the 6spd would be great but I wont cry if i dont get it....and as far as I know both the 1j and 2j both pretty much just slide in the frame of the sc300 the only thing im kinda woundering about is the 1j 92-95 I think is a odb1 and the 2j is a odb2 I am wanting to drop it in a odb2 car so i was thinking the 2j would be the better engine but seeing as I dont mess around with toyotas that much I dont know how reliable the 2j is.... now i understand the 1j is a higher reving engine but parts are a pain to find from what iv seen, now the other thing is if I did opt. to go with the 1j is the a odb1-odb2 harness convertion out there???
art
Oya thanks for the link
art
www.rccustomz.com
www.rccustomz.com
Just turbo the 2JZ that you already have...that'd be MUCH easier then swapping out engines. Its not like the Mk3 where you are better off swaping engines than turboing the N/A.
ASE: Brakes
ASE: Brakes
if you wanted to swap engines, i would suggest using the 1JZ motor as it was originally designed for the SC300, which was sold as a Soarer in japan, from 90+. the Soarer was never sold with the 2JZGTE. the US version, the SC300 had only the 2JZGE, which can easily be turbocharged and hold 600rwhp easily. this would be the easiest and most cost effective option.
for a soarer front cut, you are looking at ~$2000-$2400... and that gets you just the parts. you need to extend the wire harness and may even need to make an adapter harness for the engine harness to plug into the chassis/body wiring. its about 12 hours of solid wiring. not pretty and i would highly recommend against this sort of project for a noobie... just turbo the NA and run piggy backs. its proven and makes good power. plus the 2JZ will build more torque, mod for mod, when compared against the 1JZ.
art
www.rccustomz.com
www.rccustomz.com
Poppa J. Smurf
Poppa J. Smurf
Guest
Posts: n/a
the money you spend to turbo the 2jz-ge you could have swapped the 2JZ-GTE and put down much more power without worrying about being limited on turbo size because of that nasty ass big distributor. If you are interested in doing it the right way then shoot on over to www.boostlogic.com and look at their turbo kit for the 2JZ-GE. I was originally going to go with the turbo kit but decided it was worth just getting the 2JZ-GTE and going single with that.. which is what I am doing now. I have seen some 2JZ SC300's and they are nasty...... if money is an issue then go with the 1JZ, if its not.. by all means.........2JZ the fucker and the possibilities are endless.
You can shoot on over to www.supraforums.com and get better responses with people who have the experience with the SC300, or even try www.clublexus.com, majority of the lexus owners on SF have turboed their lex...
you will need to pull the head and replace the head gasket with a thicker one if you're trying to make any kind of power safely on pump gas to bump compression, a bolt-on turbo kit will work fine, go with whats proven, trying to go outside the box on something like this can lead you into beating your head against the wall....surely KBprice will have input on this, as he has a very hard running na-t supra
Poppa J. Smurf
Poppa J. Smurf
Guest
Posts: n/a
