need turbo help
Old Aug 19, 2004 | 08:26 PM
toyotajoe1980's Avatar
drifting in the rain
Default need turbo help
mainly i need to find the externals for a 4agte
i am in the prosess of getting a gze block and i want to turbo it but i need to find the parts i have a ct-26 and 440cc injectors but i don't know where to find the other parts i need ie. down pipe, intake and exhaust manifolds, and all the innercooler piping any web sites would help
SOLDfor sale::::ae86 sr5 converted to twin cam carburated
webers/ headers/ msd/ 4puck unsprung clutch/ 10000rpm tach
4 point harness/ custom exhaust/ custom camsSOLD
Old Aug 20, 2004 | 05:13 AM
hachibill's Avatar
yea sweet lemonade
Default Re: need turbo help
ok, i don't know where your going to get a manifold for a 4a with a ct-26 flange, yo might try www.club4ag.com for that. most manifolds for the 4ag turbo are custom anyway. i think the ct-26 would be a little to big for a 4ag. if you are going to use a toyota turbo i would go with the turbo off of a 22rte or the JDm 3tgte. if the ct-26 you have is from a 3sgte it will be better then a 7mgte ct-26.
doing a turbo ae86 means that everything has to be custom. now if you go with the HKS manifold and use a sr20det t-25/28 you could use and adapt parts to make it work instead of having to fabricate from scratch. intercoolers and piping is all custom. no one that i know of makes a kit for the corolla. just use the stock ae86 intake manifold. it will flow enough. taka's 400hp ae86 had the stock intake manifold.
you can get around 225 or so to the wheels with a t-25 and believe me a corolla with 225 to the wheels will be fast enough.
Old Aug 20, 2004 | 06:05 AM
thanks for the info i can now start fabricating the stuff i need to make this thing fly
heheheheheh
Old Aug 20, 2004 | 07:24 AM
aphxero's Avatar
"the apex hero"
Once you're at 200hp prepare to replace everything. Becuase stuff will start breaking fast!
Part of:
Wangan Midnight Maximum Tune 2 sedan expert.
APXRO: JZX100 Chaser "Odaiba Romance" 815HP/DG B1 2 overhauls. secret weapon
PM!: UCF10 Celsior "Jealousy" 810HP/DG B3 0 overhauls. vs battle car
Old Aug 20, 2004 | 11:37 AM
Jap's Avatar
Jap
VTEC Out
Once you surpass 180RWHP on a stock bluetop expect to get a GZE . Your rod will be hanging about 3"s out of your block . and the High pressure cast 9.4:1 pistons Do not take to detonation very kindly .
Get a 42mm main bottom those use the same rods as the GZE . Get some GZE pistons , 310cc 7MGE N/A Supra injectors , Megasquirt w/EDIS , Aeromotive FPR , HKS T25 Manifold , T25/T28 off an SR like Bill said . Use a Small NPR FMIC its a good size adn is good for 30+psi .
If your good at junkyarding/getting deals on forums etc you should be able to get everything for around 1k or so . Then figure 150 for piping , 50-100 for a DP , 200 for a exhuast and probally another 75 $'s at Amazon hose for turbo lines etc .
This setup should be good for around 220rwhp then your going to need to upgrade the injectors for more fuel .
The T50 is going to grenade itself alot at this power level as well . get a W58 bell housing adapter . You'll thank yourself in the long run . I belive the guy is still selling them on Club4AG for 150-200 .
Hondata saves lives
Old Aug 20, 2004 | 06:06 PM
hachibill's Avatar
yea sweet lemonade
ok soo he has 440cc 7m turbo injectors already and they bolt in so he has that taken care of already. sorry joe but turbo corolla definitaly isn't a bolt in affair. hehehehe if you need any more help or advise just drop me a line and i'll try and point you in the right direction.
Old Aug 20, 2004 | 08:21 PM
-thnx guy
-and bill i will prolly keep in touch alot now
-this project may take so time cause
i will do it a little at a time
Old Aug 21, 2004 | 12:51 PM
hachibill's Avatar
yea sweet lemonade
cool, let me know.
Old Aug 24, 2004 | 07:05 PM
i get my front mount next week
