brake lights?
Old Mar 23, 2004 | 03:30 PM
GearGrinder's Avatar
ridin high
Default brake lights?
when i press on the brakes the brake lights dont come on....the brake light on the wing works but the reg. brake lights dont
we checked the fuses and also the bulbs...what else could it be?
also the driver side head light likes to blink at people when the lights are on (go up and down) any idea what that could be???
thanks guys
Own an APBT? visit... www.mypitbullpro.com
Old Mar 23, 2004 | 04:47 PM
ridin high
The wires on there are fine
Old Mar 23, 2004 | 04:59 PM
cassio's Avatar
Vendor/Advertiser
inside the yellow box there is a connector that often shorts out, if you take that out and solder another wire in you're good to go... luckily I found 1 in good shape on an interior parts car I found.... while you're at it you may want to replace the weather stripping back there and remove your wing and put some silicone under the nounts, and also around your brake lights.
cassio
sold>> Single gt3582r powered 2jzgte
Ellis Autoworkz
Smoke 2004 LE
Crew Cab *Big Tow Package *4x2
Old Mar 23, 2004 | 05:05 PM
ridin high
Where is this yellow box located?
Old Mar 23, 2004 | 06:55 PM
cassio's Avatar
Vendor/Advertiser
the box is behind the plastic interior pieces, and kirk inside the box there is a wire that corodes as well that you can replace and will fix the problem if tht wire get s corroded
Ellis Autoworkz
Smoke 2004 LE
