22 Re Sr5
Old Sep 2, 2003 | 03:39 PM
Levi's Avatar
Default 22 Re Sr5
I just got a 1986 4x4 22RE SR5 Ext cab. I am very new to Toyota, I hear these engines are very good and last a long time. I got the truck for $800, and it runs perfect.
I had a couple of questions.
Any things that likes to go bad on these engines?
Do these trucks come with Warn locker hubs" stock"?
Thanks,
PS I wasn't sure if I could get better anwsers here or turck forum.
custom parts is our perfection.
Old Sep 4, 2003 | 07:42 AM
Levi's Avatar
Nobody has any feedback?
Old Sep 4, 2003 | 08:11 AM
agentAndy's Avatar
more class than college
sorry, i am not too sure of the toyo trucks, just supras, celicas, and carollas. i have seen a 7mgte powered truck if that halps. lol. hope you can get help.
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Sep 4, 2003 | 08:49 AM
dan's Avatar
dan
Get the fuck off my lawn
by warn locker hubs, do you mean the manual locking ones up front with the twisting acutator? if so, then yes the older models all had manual 4x4 engagement. i never knew the technical name though. it is definately good to lock the hubs and put it in 4 low every once in a while to keep things kinda lubed and make sure they are running. id say once a month, but you can get by with once every 6 weeks to 2 months or so.
i had my 89 for 13 years and the only thing that went 'bad' was the exhaust was starting to rust out, and the usual tire wear, but the truck only had 64,000 miles when we sold it because for most of the time my dad has a state vehicle and then i drove it after i got my license.
id say your normal tune up and transfer case gear oils should be checked and changed if needed and check the chassis lube points. other than that the motors themselves are very stout, but not the most powerful in the world.
Old Sep 4, 2003 | 06:01 PM
Levi's Avatar
Thanks for the feedback..
