7mgte
Old Aug 19, 2003 | 05:36 PM
J-Dizzle's Avatar
Still Addicted to Boost
Default 7mgte
kinda of a stupid question but does the JDM 7mgte engine hav the same Hg problems as the USDM 7mgte motors? cause im possibly buying another Supra soon with a JDM 7mgte....r they more reliable and better built ? just a question i thought of cause im bored...
Don't Text And Drive
Old Aug 19, 2003 | 05:37 PM
J-Dizzle's Avatar
i know the JDM motors r less restrictive when it comes to emissions other than the USDM
Old Aug 19, 2003 | 08:08 PM
agentAndy's Avatar
more class than college
the 7m is the same all around the globe. jason, you will want to keep all of your arp stuff. go to toyota and get the stock stuff to switch it out. lets swap that top piece this upcomming week.
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Aug 20, 2003 | 08:19 AM
flubyux2's Avatar
Elitist Supra Asshole :)
the JDM is the same as the USDM except no EGR cooler/pipes. otherwise, youll still need to, at the very least, retorque the bolts.. youd be better of doing the HKS MHG job while the motor is out of the car and its portable.
its hard to find a shop who can put the correct finish on the block and head... if you cant, youll have to get the Lapping tool from Reg Reimer... the SONiC tool to remove the fly-cutter ridges. im sure you know all about what it takes to puton a MHG right?
you should also hook it up w/ some ARP head studs, rather than bolts. but while your have the head off, you should built it w/ some Crower parts and HKS 272's... gasket match the intakes to the heads, knife edge the dividers, back cut the seats, blend the valve bowls, smooth the long side radius of the ports. on the exhaust side, also unshroud the valves by cutting away the divider.
Old Aug 20, 2003 | 10:41 AM
J-Dizzle's Avatar
oh ok, oh Andy im not swaping my shit in my engine cause its all goin with the car cause i dont want anything to remind me of this one u know what i mean? im workin on getting that top piece off right now, plus i think i forgot to give u some foglight stuff....
Old Aug 20, 2003 | 10:42 AM
J-Dizzle's Avatar
oh i think i know wher the center grill picec is too , ill also ring that whichever day we meet up...i work the next 3 days so it might be saturday again
Old Aug 21, 2003 | 06:53 PM
J-Dizzle's Avatar
thanks kirk
Old Aug 21, 2003 | 07:43 PM
flubyux2's Avatar
actually, its the exorbitantly low torque values that the factory applies to the stock bolts, and the fact that EVERY service manual abides by the 54 ft/lb spec... so ANY mechanic that is even half-way decent at reading and followin instructions will propagate the BHG problems of 7M's... the EGR cooler and the heater core hoses dont help anything, neither does the placment of the stock cat... they all contribute to keeping the back of the block hot, for much longer than the rest of the motor... this will cause warping and distortion as the rest of the motor cools after shutdown, but since the EGR cooler, stock precat, and heater core are all grouped around the #6... its gonna stay hotterrr for longer... not good
