Subaru Tech All We'll Drive
ATTN. subie guys
Old Nov 8, 2002 | 04:22 PM
quicksilver EK's Avatar
The one punch machine gun
Default ATTN. subie guys
i was wondering how difficult a swap with a 2.5rs is when you are swaping in the JDM turbo charged motor,is it hard cause i dont belive ive ever seen one in person.Are there any sites i can go to to see this stuff ??
Thanks in advance
-steve
97 ITR-Mugen Equiped
04 Honda 600RR
Old Nov 9, 2002 | 05:46 PM
2TurboImports's Avatar
sooo...where's the turbo?
mechanically, it's prolly on the same level as a honda engine swap....maybe easier cuz the engine weighs alot less, however....wiring si the hardest motherfucking part. I was going to do an STI swap, but then I read a somewhat how to and you have to remove the entire dashboard and re wire just about all the under dash wiring...not really something I look forward to...there are quite a few sites you can go to....
www.rallispec.com if you have $$$ they will do the swap for you.
www.i-club.com do a search there on sti swaps and you'll get a bit of info
there are a few other sites, non I can recall though....
But for the level of difficult and money it would cost, you can build a 2.5L motor and have super gobs of torque...god knows I will....
Old Nov 29, 2002 | 11:03 PM
ibjhb's Avatar
I'm sure someone on i-Club would know....
James
Old Nov 30, 2002 | 10:26 AM
Dirt Man's Avatar
Sucks to be You!
Quicksilver,
It can and has been done.... but the first issue is the wiring harness, second issue is the front crossmember and third issue is the expense. You might be better off just buying the turbo kit from Ludespeed or SPO motorsports and having it done to the 2.5L H4. Then buy the Vishnu ECU to have it tuned correctly. The biggest advantage is that the 2.5L H4 has more low end grunt when turbocharged and can be tuned with the Vishnu to have your torque band kick in at 2500 RPM vs. the 2.0 Turbo's 3200 RPM.
When I still had my RS I looked into the cost to Turbo and the average cost to do it correctly was between 5-6500 grand.
I'm meaner, stronger, and way more bitter than you are! So don't FUCK with me!
