Subaru Tech All We'll Drive
ATF ratio
Old Aug 16, 2011 | 09:14 AM
JayBurd3's Avatar
06' wrx
Default ATF ratio
I just put a aem wideband in my car and at a idle is is reading around 17 crusing it is about 14ish and under full boost it is 12.6. the car is a 06 wrx 18 psi how bad are the ratios.....
Old Aug 16, 2011 | 12:44 PM
jcssti6265's Avatar
TampaBayTunedPerformance
Idle is way lean, should be much closer to 14.7, crusing sounds good, for stock turbo 12.6 is good for boost.
Old Aug 16, 2011 | 06:28 PM
psi_R170's Avatar
Better known BrownMK3Kid
do you have a tune? the lean afr's at idle might be a vacumm leak maybe?
Old Aug 17, 2011 | 02:12 AM
jcssti6265's Avatar
Possible but you would have low vacuum on your boost guage and very bad idle quality.
Old Aug 17, 2011 | 06:30 AM
psi_R170's Avatar
op any other info?
Old Aug 17, 2011 | 12:44 PM
JayBurd3's Avatar
06' wrx
It idles fine and runs great! Could it possibly be o2 sensor? It was tuned by previous owner. I going to get snowman to tune it I just wanted to see how bad the ratios were and under boost it is 12.3 not 12.6 typo
Old Aug 17, 2011 | 04:46 PM
Tampabaytunedinc's Avatar
Might be the sensor, take it out anfd test it. Easy way is to spray bake clean on a rag and hold it over the sensor. It should go rich, 11 or lower. Or u could check the voltage of the oem oxygen sensor. That will tell u if u are,actually lean at idle.
Lumberjack
Aug 14, 2007 03:03 PM
Whaazup17
Jun 29, 2006 05:41 AM
Cronic
Sep 11, 2003 12:22 PM
