Subaru Tech All We'll Drive
wrx need some help
Old Jun 21, 2011 | 04:03 PM
cubanoNpr's Avatar
Default wrx need some help
hey what up guys i got wrx and i blown my motor its a 03 with the 2.0 motor i want to no if i buy the 08 motor the 2.5 will all my parts off my 2.0 motor fit on 2.5 like the vacumes and turbo or will i have to change alot to make it work i just really need help thank if u have some info that i cen use pm me if u cen i will appricate the help thank
Old Jun 21, 2011 | 10:31 PM
kirbykirb's Avatar
IT will bolt up, but the 2.5 motor has subaru v-tec which is called AVCS, and it will require new tuning, new eCU and tons more work. it is not a simple *drop in, bolt up and hook up* swap.
Find a EJ205 engine and swap it in, 2001-2005 will be a direct swap and you can reuse everything from your old engine and save $$$ and time. DO not swap to a 2.5 08' motor if you're interested in keeping it simple.
tl;dr: yes it's possible, its not direct you have to have a bit of fun.
You can buy a EJ22 and have it swapped for less then 2500$ at most shops. Don't get a JDM motor as well.
Old Jun 22, 2011 | 06:13 AM
Niburu's Avatar
Sic semper tyrannis
also do some research here NASIOC
2011 Subaru Forester - the daily driver kid hauler
1990 Miata - track whore
LOVE THIS TAMPA CAR RACING SCENE
Old Jun 22, 2011 | 08:32 AM
TPNORTH's Avatar
hey man where are you located that will help im sure if your near another member someone can come by and help you out and if your in pasco or around here i can help you out even help swap it i have everything at my house since im working on mine lmk Try and give us as much info as possible like what happened why you wanna swap what your looking for as in goals stuff like that gives us more to work on.Sorry for the run on sentance!
Old Jun 22, 2011 | 03:26 PM
cubanoNpr's Avatar
thanks for the info it help me out alot i blow my motor so i waz goin to buy a 08 2.5 to drop right in and now i no i want it to be simple thank tr^^^^^ttt
Old Jun 23, 2011 | 07:11 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
yeah you'd be better off with another 205 block, a 2.5 seems like a waste if you arent going to be using the extra displacement for performance purposes. and i cant imagine an 08 2.5 block being very cheap.
Old Jun 29, 2011 | 08:37 PM
bebesito21's Avatar
mES the Mekanic
you need a cam sensor adapter bracket - cosworth makes one. strip the 08 block down - you cant use the harness, the intake, almost none of the sensors. AVCS can run disabled. you need the coolant temp sensor from the 2.0. good luck if you decide to do it
Build it, race it, drive it, daily. I can get you great deals on parts. www.dailydrivenpower.com
Old Jul 1, 2011 | 07:48 PM
tommy02wrx's Avatar
wagon FTW
you can use a use a 08 2.5 block but you have to reuse your 2.0 heads sensor ect... it will all bolt up and you will need to get a tune
