Subaru Tech All We'll Drive
A/c compresor problem
Old Oct 16, 2010 | 03:57 PM
scubie2769's Avatar
Default A/c compresor problem
So I turned on my a/c today on my 04 sti and is blowing hot air,i open the hood to check and the compresor is not moving, I check the relay and they are good, check the fuses in the car and they are good. I was thinking it might be low on freon thats why the compresor is not kicking in? I need help! Let me know your toughs or if you have a.compresor
Old Oct 18, 2010 | 05:54 PM
kirbykirb's Avatar
I have a compressor if you need it.
It can be of several things, theres a leak, theres no oil for the clutch internally for the compressor or its not pluged in correctly for the voltage to initiate the clutch.
Old Oct 19, 2010 | 11:33 AM
sil80redtop's Avatar
It might be a waste of time, but try charging it. $20 bucks at Autozone and cheaper than having someone look at it. I haven't heard about too many of these compressors failing, but I think it's pretty common for the expansion valves to go bad. Were you getting a crunching sound from the compressor when it cycled on and off?
323whp?
Old Oct 19, 2010 | 12:11 PM
scubie2769's Avatar
Yeah I'm thinking about doing that....no sound from the compresor just doesn't move...i heard if the car is low on freon the compresor won't turn on
