Subaru Tech All We'll Drive
Anyone can bend/weld piping for i/c?
Old Aug 7, 2010 | 10:30 PM
Wingless06subie's Avatar
Default Anyone can bend/weld piping for i/c?
Hey im new to the area and i am thinking about going to a composite intake manifold off a legacy and a legacy throttle body to make a reversed intake manfold setup easier and i would just need to buy a i/c core and need someone to build the pipes.
Any recommendations would be great thanks!
Old Aug 12, 2010 | 04:37 PM
JonLGT's Avatar
Just for decoration
You might want to weigh the gains of a reverse manifold to how much time and money you will spend in the process.
What are the supporting mods?
Old Aug 12, 2010 | 06:47 PM
The gains from running a composite intake mani is cooler/denser air which means efficiency, a chance of making more power than a stock sti Aluminum intake mani which can get up to 185*F after a couple of hard runs when the composite wont get above 85*F. Heat absorption properties of the plastic are so much better than aluminum anyways.
I was gonna do a rotated 35/.82r since this is not a going to be a street car since i can't afford the damn insurance.
Motor is gonna be built first. Top to bottom. No steps are gonna be skipped.
I dont really want to spend the money on a perrin fmic or aps or full-race, UR, AMS, etc etc.
When you can do rotated intake mani just need to buy GS phenolic gaskets-$65, Mishimoto fmic-$380, tial bov flange-$22, tial bov-$230, Used lgt intake mani-$100
just need piping lets say ($400 rough estimate), ill then spend $1,200 and have a proper kit will a little faster spool, and cooler temps in my intake mani and save 3 ft or piping than doing a traditional FMIC kit. Maybe even clock the turbo to make piping shorter.
So would i want to spend $1,200-$1,400 on more piping, which means a little more lag,
if i go this root ill still need a -Bov & flange($250), and i would have to modify the pipe going to the turbo anyways to work with the rotated turbo.
Here's the setup on a sti done properly.
Fine Line Imports
Yeah it would be some work, but way worth the money for how efficient it would be.
Old Aug 13, 2010 | 03:30 AM
kensworth's Avatar
pm'd
Godwin-Singer Machine Shop for all your machining/engine building needs!
727-896-8631
Old Aug 13, 2010 | 07:51 AM
racer_x's Avatar
vroom psshh.
Interesting. I'll be lurking around on this... keep us posted on the build
Old Aug 13, 2010 | 07:54 AM
bikeimports's Avatar
PM sent.
Old Aug 13, 2010 | 09:21 AM
blacksti's Avatar
DudeMan
Pm me if you're near the st Pete area I have shop for you. They have record breaking cars at the shop right now.
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Aug 13, 2010 | 01:32 PM
Hell yea thanks guys for the numbers.
Ill be hitting some people up when i move to tampa from the panhandle.
Old Aug 13, 2010 | 07:06 PM
iamboon's Avatar
Check out LHT Performance in the vendor forum... highly rated by several customers including me. Check out his work!
Old Aug 19, 2010 | 01:53 PM
prgoya12's Avatar
DB Fab
