Subaru Tech All We'll Drive
Stripped Stud Removal
Old Mar 18, 2010 | 09:25 AM
mantra1's Avatar
Shaggin' Wagon IV
Default Stripped Stud Removal
Need some help. I have a stud on my vf43 that is completely stripped (14mm nut won't thread) and cannot seem to get the damn thing off, even using PB blaster, heat and vice grips. Problem is, the turbo is already on the car and don't want to remove in order to break the stud and replace. Any ideas on backing the stud out while the turbo is still installed. For reference, it is the #1 stud that is stripped. This image is just for reference.
2011 TSX Sportwagon
Old Mar 18, 2010 | 02:18 PM
ShockerGT's Avatar
Shake n bake
When Brian's (bcs925) vf39 had a stripped stud, I took a dremel and and ground the threaded part into a rough square shape and then used a pair of vice grips set so that you really had to use A LOT of strength to get them to lock and was able to get it off within an hour or two. BTW, mechanic's gloves work well in reducing the pain caused by squeezing the vice grips at that setting. Also sprayed the hell out of the stud with PB Blaster.
All of this was done with the turbo still on the car, just made sure to use some tape to cover all of the openings when grinding (turbo outlet, turbo inlet, throttle body).
Old Mar 18, 2010 | 04:00 PM
bcs925's Avatar
buy a new turbo, its not worth the hassle... or just do a lot of drinking during the removal... that was our problem we werent drinking...
WRX TR... Tampa Racing Edition... because its sure as hell not Tuner Ready
Old Mar 18, 2010 | 04:10 PM
chome's Avatar
Will sleep for food.
When I stripped out my shifter, I just took it to Acutek in Largo and they fixed the threading for $10. I didnt even take the shifter out of the car.
Also, I ran my VF39 with only 4 out of 5 bolts connected for forever without a single exhaust leak.
Old Mar 19, 2010 | 09:50 PM
wrx_kid's Avatar
same im running 4 out of 5..running great no leaks!
If you have been mislead or fraudulently persuaded into buying a timeshare in the last 2 years.. I CAN HELP!!
Old Mar 19, 2010 | 10:25 PM
Jeff240sx's Avatar
Cpt. Negative
Is the stud part of the turbo? If so, cut it, drill it, install a helicoil and a high-grade stud in there.
Running 4/5 bolts is okay, but I wouldn't do it if I had another option.
** This space reserved for someone else's witty quote **
Old Mar 20, 2010 | 06:43 AM
WTFchuck's Avatar
oh WTF
if there was no airfest this weekend i'd be able to help you out
2011 Mustang GT 5.0
Sterling Grey Metallic
401a, comfort pkg, electronics pkg, security pkg, 3.73 gears
Orderd Sept. 29th, Built Nov. 8th, Delivered Nov 18th!!!
Old Mar 20, 2010 | 06:50 AM
mantra1's Avatar
Shaggin' Wagon IV
I had enough threads on the stud in order to get the nut to fasten. There was no way that stud was coming off without just cutting and drilling it out. Thanks for your replies.
Oh, btw, the vf43 and Invidia uppipe are installed and car is running sweet
2011 TSX Sportwagon
Old Mar 20, 2010 | 09:41 AM
chome's Avatar
Awesome!
Old Apr 24, 2010 | 12:52 PM
socalwrx's Avatar
I've running 4/5 on my WRX, #2 (on the OP photo) turbo internal threads got mangled when I replaced my downpipe. Can't get anything to thread in there. I'm waiting for the smell of fresh exhaust wrap to burn off before I try to figure out of I have an exhaust leak or not. Which of the 5 are you running without Chrome and WRX Kid?
