Subaru Tech All We'll Drive
Why the need for a iwg bracket?
Old Dec 4, 2009 | 11:10 AM
zenith's Avatar
Default Why the need for a iwg bracket?
Just wondering why you need a bracket to close your iwg cus when I put everything in I took the hose off that led to the iwg. So if there is no line leading to that then how could the arm open the door?
C:\Documents and Settings\Khursheed\My Documents\My Pictures\Picture\800px-2006_gsxr750.jpg
Old Dec 4, 2009 | 11:11 AM
blacksti's Avatar
DudeMan
Pressure can cause it to open maybe? Lol
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Dec 4, 2009 | 11:33 AM
WTFchuck's Avatar
oh WTF
yes even though there is no vacuum to open it up... through exhaust pressure it will open
2011 Mustang GT 5.0
Sterling Grey Metallic
401a, comfort pkg, electronics pkg, security pkg, 3.73 gears
Orderd Sept. 29th, Built Nov. 8th, Delivered Nov 18th!!!
Old Dec 4, 2009 | 12:02 PM
fitbikeco's Avatar
false. why doesnt it open when the actuator is disconected??? i dont think it will open but it may under really high exhaust pressure
Old Dec 4, 2009 | 12:26 PM
WTFchuck's Avatar
oh WTF
it doesnt open fully... but it does open
2011 Mustang GT 5.0
Old Dec 4, 2009 | 12:42 PM
Tupass's Avatar
Only Bolt ons!!
just weld that shit in place.
TampaBayTunedInc.
Area51Tuned
Old Dec 4, 2009 | 02:43 PM
schoellnasty's Avatar
With no vacuum line the only thing holding the wastegate closed is the spring. VF series turbos have like a 10psi spring so it is possible to blow the flapper open at higher boost levels. This is why people put helper springs on the stock turbo. You could run this way, but the proper way to do it is either a bracket or welding. IMO theres no reason not to run a bracket since you can make one with like $5 of stuff from Home Depot.
Old Dec 4, 2009 | 07:43 PM
zenith's Avatar
Do i need to take the turbo off to weld it shut cus i really dont feel like doing all that shit over again. Meaning will a bracket or welding be easier cus I can order the bracket.
Old Dec 4, 2009 | 07:53 PM
blacksti's Avatar
DudeMan
Nope, just remove the DP
2jz mustang build
Old Dec 5, 2009 | 03:26 AM
Tupass's Avatar
Only Bolt ons!!
u can weld the arm from the outside ,no need to remove tha dp.if u need help_shared_pm me.I can hook u up...
TampaBayTunedInc.
Area51Tuned
