Subaru Tech All We'll Drive
New subie owner. help
Old Aug 2, 2009 | 05:20 AM
PbH's Avatar
PbH
Default New subie owner. help
Hi just bought my 2005 wrx sti a couple days ago, and i have some questions. Its been lowered and it makes a cluking noise when i first start to roll in 1st or reverse, should i worry? what should i check?. second i have ic water spray button but no resevoir where is it supose to go?
Old Aug 2, 2009 | 05:37 AM
tommy02wrx's Avatar
wagon FTW
common problem with the blob eye sti struts the rear sturts are missing it felt cleaner best thing to do is clean and lub the shaft or buy after market ones
Old Aug 2, 2009 | 05:40 AM
PbH's Avatar
PbH
what?
Old Aug 2, 2009 | 05:49 AM
ShockerGT's Avatar
Shake n bake
He's saying the stock struts are prone to clunking. The solution is to get aftermarket struts.
Old Aug 2, 2009 | 05:51 AM
schargd's Avatar
Go by S & R Performance. They have done tons of Subie work and can answer all your questions.
Old Aug 2, 2009 | 08:21 AM
racer_x's Avatar
vroom psshh.
with something as simple as struts, do them yourself. Have your suspension aligned at S&R, though
Old Aug 2, 2009 | 03:20 PM
PbH's Avatar
PbH
ok. can the clunking of the strut happen when i shifting if not what should i look at. suspension seems tight im concerned its the drive line. it only happens when shifting and starting to roll. Again its a clunking sound
Old Aug 2, 2009 | 03:43 PM
specVmatt's Avatar
400hp club, barely
The intercooler water sprayer tank is in the trunk on the passenger side beneath the carpet. You will see a lid. Just open it and bam.
Coyote
Old Aug 2, 2009 | 04:12 PM
autocannon05's Avatar
k since its happening when you shift it may be your rear diff bushings which could be going out. Those are prone to make a nice clunking sound when you shift.
I got these and I strongly recommend them, it got rid of my clunk when I shifted and made the rear end alot "tighter". http://www.turninconcepts.com/produc...d=24&osCsid=d9
vf43...
Old Aug 2, 2009 | 05:42 PM
PbH's Avatar
PbH
how do i test the bushings?
