The Self-Tuned/Opensource Thread
The Opensource/Romraider route of engine management has grown in popularity and sophistication in the past couple years here in the Subaru community. I know quite a few people here in Subaru Tech tune their own cars, and a few tune for others as well. I wanted to start this thread so local people could help each other out instead of having to wait for help from someone hundreds or thousands of miles away over on RomRaider or NASIOC.
Things we can talk about:
-Your setup (year, engine, mods etc.)
-Your tune (the basics like boost - AFR - timing, aggressiveness, your approach)
-Things you are experimenting with (improving MPG, driveability, etc.)
-Problems you are having with your tune
-Getting started with tuning
-anything else related to tuning/logging/opensource etc.
Oh and please, lets keep the TRama out of this thread. Subaru Tech has been cranky about tuners lately, and I dont want to see a repeat of the SS thread awhile back. If you aren't adding to the discussion or helping someone out, DON'T POST.
I'll start things off...
My setup:
2005 EJ205
Blouch 8cm^2 18G
DW 740s
Walbro 255
STi TMIC
TBE
Perrin EBCS
GMS Turbo Inlet
Stock airbox
Stock headers
My tune is not all that aggressive IMO. I am running 21psi, 11.1 AFRs, and 19* at redline (12* at peak torque).
I am currently experimenting with disabling Closed Loop Fueling and running entirely in Open Loop.
My setup:
2005 EJ205
Blouch 8cm^2 18G
DW 740s
Walbro 255
STi TMIC
TBE
Perrin EBCS
GMS Turbo Inlet
Stock airbox
Stock headers
If you want a good read on AFR theory/strategy on Subarus in particular, check this out: Let's talk AFRs - NASIOC
i tune myself but utec and a g35
I tune myself... just havent got a chance to write a whole story about it. Mod list in the sig
My approach is pretty basic: see what others had done and shared and tweak it to run more boost/fuel/timing/etc to push the envelope then pull back if I knocked and/or overboost. One thing I've notice I havent liked about any map I've seen or made personally is boost/wgdc on a VF39. None of them seem to build boost as fast as I see some of the pros do on NASIOC (proven power). Or maybe 2 years with a TD04 spoiled me. But, thats something on the to do list. I try not to change too much stuff for each run to isolate changes.
I have some gremlins in the timing up top. I'm thinking its pulling timing due to low fuel pressure because of crappy stock fuel pump (need to log it, just never happen to have the laptop during high speed runs as they dont happen often). I'd like to get some dyno time really hone in on some parameters. I will be ordering a new FP on sunday so hopefully that fixes it but I'll def log/tweak/reflash after the install regardless.
I'm a big advocate of using 3port EBCS. I love my Grimmspeed, I think its responded very well and trust it more than MBC (I base this on no real experience but MBC and BOV seem to be that stereotypical ricer stuff, which I know isnt entirely true but whatever).
I wish I had more time to play with my tune lately but work has been killing me and it seems the weekends I don't go to work it rains all day. But my next project is to get a wideband to do more advanced tuning (open loop fueling, tip in, and open loop maf scaling) All seem pretty easy to do based off what I've read and between doing all three should yield some good gains.
So all in all its a never ending process but at the end of the day I'm happy with my power, fuel econ, drivability, etc so I cant complain.
WRX TR... Tampa Racing Edition... because its sure as hell not Tuner Ready
So you've tuned your own car so far without a wideband??? You realize that the stock narrow-band front o2 sensor shows 11.0 whether it's actually 11.7 or 9.0 right??? Subaru stock sensors are not really acceptable to use for WOT tuning...
Siegel
Siegel
Scott
Forged Performance
www.forgedperformance.com
770-792-0202
Siegel Racing
404-388-8751
www.siegelracing.com
Driver / Engineer / Tuner / Instructor
Scott
Forged Performance
770-792-0202
Siegel Racing
404-388-8751
.Oh and this^^^. Ive seen a full point difference between the stock sensor and my Innovate at WOT. Running someone's safe base map without a wideband is one thing, but I would never think of pushing it any further.
