need help!!!
only way to tell would have a compression test done
The way to tell if its tuned.. Go do a 5th gear pull. If it hits boost cut (car bucks and backfires) Its most likely untuned. With a turbo back exhaust the car will hit higher boost then what the ECU will allow.
The boost cut in a Stock STI is 14.5 PSI. Not sure where the 7 PSI safe mode came from
