Small A/C Issue
Just to let you guys know...we have an AC machine. If you add Freon to a system because of a leak. Chance are there is O2 in the system now. You need to pull a vacuum and recharge the system.
I can also check to see if the compressor is doing its job as well. With Gauges I can tell if we have good air flow across the condensor or if there blockage in the lines.
or a whole in your line... like mine
