Prosport Track times! JDM ups.
Well we Managed to run the car at the track this past weekend. Kind of disappointed. Ran two back to back 12.6 on the DD map. At 19PSI
Pretty sure 5th gear is whats killing it. Before reaching the end theres always 30-40 yards left and i have to shift into 5th. Cough Shitty gearing 06 sti!!! When i go into 5th there is no boost AT ALL! Complete LAG! grrr.... Pretty sure this big hotside is whats causing it!
Pass one:
.588
1.747
5.238
8.096
86.74
10.537
12.626
108.98
Pass two:
.209
1.936
5.423
8.248
88.55
10.644
12.672
112.40
Before the bashing begins on me or the car. This is a very conservative DD map. We didnt bring the AP or any race gas this time to run the Race map and this was my first time running the car on this HD clutch and light flywheel.
Pass one:
.588
1.747
5.238
8.096
86.74
10.537
12.626
108.98
Pass two:
.209
1.936
5.423
8.248
88.55
10.644
12.672
112.40
Pass one:
.588
1.747
5.238
8.096
86.74
10.537
12.626
108.98
Pass two:
.209
1.936
5.423
8.248
88.55
10.644
12.672
112.40
Pass one:
.588
1.747
5.238
8.096
86.74
10.537
12.626
108.98
Pass two:
.209
1.936
5.423
8.248
88.55
10.644
12.672
112.40
that trap speed should be higher regardless of the time it still makes over 400whp... i think glenn should get it retuned
Rotated 3583R
Idk about getting it returned. and im not sure the DD map makes 400whp!
The Stage 2 Aggressive DD map makes 400whp. and the Stage 3 race gas map makes 504whp.
We were running the Stage 1 DD set at 17psi, i bumbed it up 2 psi before raceing it.
This is what i dont get. First pass great 60' faster et. lower trap. Second bad 60' .5 off et and 4mph faster trap..did you spin off the line? Whats the tire setup? 225's
Specs in garage.
Specs in garage.
Figure out why you aren't making any boost in 5th, that would be why the traps are so low. Shifting into 5th should place you in the meat of the power band so lag shouldn't even be an issue.
550/550
trap is still low for the 1/8 too
