Subaru Tech All We'll Drive
Brake light coming on and off
Old May 12, 2009 | 08:30 AM
SteelDragonSTi's Avatar
The slowest STi in the US
Default Brake light coming on and off
I just came back from the supermarket and noticed the brake light come on. After a few seconds, it went off. This happened a few times. When I moved the car, depending on its motion, it would flicker on/off. I checked the fluids and they are on max. I checked for leaks and couldn't find one. I do have an aftermarket radiator overflow tank that did spill out some fluid, But I don't know what that has to do with the brake issue other than it being close to the metal brake line.
Any thoughts?
2006 Subaru CGM STi
Powered by My Retirement Funds
Old May 12, 2009 | 09:09 AM
ryan_west06's Avatar
dude im dealing with the same thing. But i think its the rear sensors. When i did my 6 spd conversion in the rear i kept the stock wrx ABS sensors. I noticed the STI sensors are a little longer. Ill get around to fixing it one of these days lol, breaks work fine tho.
Old May 12, 2009 | 09:18 AM
racer_x's Avatar
vroom psshh.
I couldn't help but laugh my ass off when I read this because (at first) I thought you meant the outside brake lights lol
The coolant overflow reservoir has nothing to do with the brakes, can't affect it.
Does it say "BRAKE" or "ABS" ?
Old May 12, 2009 | 09:46 AM
Yeah, I thought the same thing just now. Its the "Brake" light.
I pumped the brakes and they hold fine, no feel of fade or pressure loss. I said about the overflow tank because it spewed fluid in the area where there is a connector plug. That connector is attached to the metal tube running back to the master cylinder.
I'm just having bad luck with this car overall.
2006 Subaru CGM STi
Old May 12, 2009 | 10:05 AM
xxBoost Junkiexx's Avatar
MPG FTW!
Could be the G-Sensor for the ABS right under the e-brake. Never seen one go bad on an STi though.
Manny
Old May 12, 2009 | 11:41 AM
ShockerGT's Avatar
Shake n bake
I know my Legacy has 2 "BRAKE" lights on the insturment panel. One is when the reservior fluid is low and the other one is when the handbrake is engaged.
Old May 12, 2009 | 05:20 PM
racer_x's Avatar
vroom psshh.
Manny
Not sure about this one, but I would check the parking brake
Old May 13, 2009 | 04:15 PM
My brake light comes one like 5 min after driving.
Here is whats weird, ill pull out of the drive way, when i come to my first stop sign the brakes feel really weird. Pedal almost falls down when pressed. I pump the brakes one time and there normal. ABS light comes on as well. this is why i think its the rear ABS sensor because i never switched it over the the STI. I have the sensors but im lazy lmao.
Old May 13, 2009 | 05:14 PM
I found the problem! It was some connector that is attached to the bottom of the e-brake lever. Apparently it got loose and started to shake around. That shake caused the sensor to activate thinking the e-brake was up.
Thanks for the info on this thread.
2006 Subaru CGM STi
Old May 13, 2009 | 06:49 PM
racer_x's Avatar
vroom psshh.
^no prob, glad you fixed it
^^ ryan, bleed the brake system... it is impossible that your problem is electronic; it must be an air pocket in the brakes. LOL @ too lazy... i feel ya man
