help with motor rebuild 07 STI
My compression test. All the cylinders were at 140 except cyl 4 which was at 135. A compression test for the 07 sti according to the shop manual should be in between 182 and 142 for normal operation but should read 160 to 180 to be good. My motor isn't bad yet but it will eventually go and I figured since its going anyway why not do the full rebuild I wanted to do it anyway for what I plan to do for the turbo setup.
Satin White Pearl 2007 Subaru Impreza WRX STi Limited
135 really isnt that bad you could have def kept driving it like that ... they recommend you rebuild it if it goes under 128 but thats a nice build you have there!
so how experienced are you with rebuilding motors? because maybe 1 person in the suby tech area has actually built their own motor and im not talking about bolting your heads to your block ... im talking about a full build like youre doing and saying 1 person is being gernerous...
honestly i would call a shop that has built blocks with a good rep and ask the questions . and take it slow!!!! dont want to fuck anyhting up good luck and post pics
good luck
good luck
your so wrong its not even funny.
yeah ill definitely call a shop but i couldnt have a shop do it do to money constraints thanks for the advice on everything though. and concord how am i wrong? ive done my research on it and my buddy works for subaru plus he's like a subie guru. as far as experience blacksti, i dont have any on doing it myself but i got the know how and im definitely gonna take it slow, i got the shop manual and im gonna make sure to double check everything and hopefully my friend out here in hawaii whose from tampa can hook me up with some connects hes got back there. im hoping to learn a great deal from this experience. oh yeah and the gauge i used was the craftsman compression tester from sears and i think the only thing i didnt do according to the shop manual was to do the test while the motor was hot... that probably had my reading off from what i was looking for but either way my tuner said thats what the problem was and either way still i want to rebuild it for the power gains and to be ready for the turbo im gonna get.
def goodluck with the build and from now on spend all your time here:
Built Motor Discussion - NASIOC
you will def learn alot.
vf43...
vf43...
do it with the motor warm will give you better results. like i said you could have kept driving the car as is but theres nothing wrong with a built motor lol good luck and keep us updated
