leak from somewhere
I recently installed my egt probe. We used the hi temp threader on the egt bung and sensor in the threaded header. Bought new gaskets and tightened them all to spec. I checked all my hoses and everything. We keep just trying to re tighten the bolts, but I am not hitting peak boost. I think my header is leaking or something. Checked it to see if it leaks, but it might be so minor that we don't notice or i might have a very slight leak on my hoses. I have no idea. My boost gauge usually reads 19psi or so, but now it's only reading 16 psi. Anyone got any ideas?
New setup in progress
do a boost leak test on it.....only way to narrow down the leak for sure and the easiest. Have you tried getting under the car while its running(take safety precautions- jack stands, goggles...etc.) and listen for the leak from the header. You could spray some soapy water where the header flanges seat and make sure they aren't leaking.
550/550
you would still build boost if that was the case with the egt i had a big leak before my turbo and still build full boost
Are you sure man. I don't think so... I dunno what the problem could be if that's true.. I was hitting peak boost and the only thing i did was the egt install..
