uppipe gasket
anyone have one that goes between the manifold and uppipe laying around? hoping that leak is one of my big problems im having so if you got one let me know please
manny at mastro is your friend. i need to call over there to order a new exhaust manifold gasket anyways lol
[/center]
[/center]
:: Crucial Racing Systems - The parts you need for the performance you want
this is what i was talking about. what i remember was they shipped to my house within 3 days.
boost leak the intake manifold and check the o rings on the injectors too.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
eh if i have to order them i dont want oem i want better like copper or thicker
word... thanks
idk i had an oem replacement in there and it went booboo... if i use two oems will it make it better or be totally irrelevant
the only way a gasket should ever go bad is either during installation or if there is a leak. where superhot air is escaping. Shouldn't need a thicker gasket to make up for any leak, if theres a leak then either the bolts aren't tight enough or the two pieces don't fit together correctly.
I believe all OEM exhaust gaskets are metal as well, they are plenty strong.
[/center]
[/center]
grimmspeed ftw! i just got the whole kit from them. they oem quality but they got more steel layers, thicker than oem.
99 Prelude SH-slow but sooo SEXY
04 WRX-300WHP silver bullet
09 Si SEDAN UNDER CONSTRUCTION
