Subaru Tech All We'll Drive
p2096
Old Oct 27, 2008 | 05:53 PM
WhatWRX's Avatar
Default p2096
P2096 Post Catalyst Fuel Trim System Too lean Bank 1.
i posted a thread about this code during the summer. all the answers went to my rear o2 being bad. i replaced it and it went away till last monday. i erased it and then it came back sunday. im not sure if it is the heater element going bad with the new one or what. right now im just trying to think what everyone might think what it could be.
R.I.P. BRIAN 2/7/89 - 11/23/08
Old Oct 27, 2008 | 05:59 PM
LDadrenaline's Avatar
yeah, I drive a miata
do you have one of those CEL delete wires wired into it? could be a bad wiring job
[/center]
mranlet's Avatar
eats gunpowder
Did you replace it with a generic brand or OEM Subaru one?
BTTS, STFU&D
Old Oct 27, 2008 | 06:07 PM
WhatWRX's Avatar
no cel deletes and i replaced it with a bosch
Old Oct 28, 2008 | 02:07 AM
fat angel's Avatar
Secret Squirrel
if you have an aftermarket exhaust then you might want to have a delete put on or the light turned off. it will keep coming back otherwise. i even doubt the other was bad.
Old Oct 28, 2008 | 09:14 AM
WhatWRX's Avatar
yea thats what i was told because im on my stock ecu and that code is gonna come back even though im tuned for it.
Old Oct 28, 2008 | 09:17 AM
anarchypro's Avatar
fozzy tech
mike that code means your car is gonna blow up, i think you should drop it off at my house so i can drive it!! lol but truly i shouldn't be anything to worry about
Tampa bay tuned inc.
Old Oct 28, 2008 | 09:26 AM
blacksti's Avatar
DudeMan
told yaa theyre cheap to buy the delete
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Oct 28, 2008 | 10:45 AM
3gsucks's Avatar
you need to have the code turned off. when a code is disabled they dont pop cels.
Dont put a resistor or block of on it because for the 32bit ecus they still use the rear o2 for some of the learned afr's to that could make you run rich or lean i dont remember I think it was rich though.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Old Oct 28, 2008 | 12:58 PM
WhatWRX's Avatar
alright thanks ^^^^
