Boost creep help
well if its a 3" exhaust either go down to a 2.5" or get a different exhaust with a cat or resonator.
also is your car tuned? if not, that could be the issue as well
[/center]
[/center]
buy my exhaust it won't creep
2011 Mustang GT 5.0
Sterling Grey Metallic
401a, comfort pkg, electronics pkg, security pkg, 3.73 gears
Orderd Sept. 29th, Built Nov. 8th, Delivered Nov 18th!!!
2011 Mustang GT 5.0
invidia g200, never had problems at all with creep
2011 Mustang GT 5.0
2011 Mustang GT 5.0
How much boost are you running with your MBC?
MBC is the reason you are creeping most likely. get a tune, but know that unless you have a custom tune you wont be able to run your MBC.
[/center]
[/center]
Get rid of the HKS DP. That's the one with the plate over where the wastegate is. It is the very definition of creep. Get a bellmouth. That will solve the problem without a doubt.
Common...you guys are slipping. You should have been all over that and not going down the MBC route.
