Subaru Tech All We'll Drive
fuel vapor delete mod
Old Sep 28, 2008 | 12:02 PM
skoloseven's Avatar
Default fuel vapor delete mod
Ok, so I posted a thread at EGR Delete 02 WRX - NASIOC
it talked about how I broke the fuel vapor switch, similar to the one below:
Then somone posted a graphic about how the system works, and explained that I actually broke the switch.
I found some other threads where people had actually done this for a MOD, I don't know why but I guess it's a mod... Anyways, I did it to my car too! It threw code p0444
Here's the mod pic:
The car ran alright, but it experienced some hesitation I think due to crazy fuel mixtures and not being tuned. I put it back together, and added a nifty aircraft fuel line from our ultralight. It's nifty 80's neon green lol, but it's STRONG. Aircraft parts on a subaru, now that's sexy.
So after a couple of hours, and testing.. this mod is useless unless your tuned IMO, and will just make your car run like dog snaps. However, I would think that if I was tuned, I might see a .000001% hp/tq increase--- but here's the kicker
is the fuel vapor warm?? Isn't fuel vapor actually more explosive than the gas itself?? So by removing this, I actually lose horsepower regardless of tuning, because there is less explosive chemicals in the air mixture...
Anyone else mess with this or have experience??/
Old Sep 28, 2008 | 12:06 PM
blacksti's Avatar
DudeMan
its called the purge control solenoid and valve its emissions bs... im removing mine right before i tune the valve cant handle high boost so it breaks and it turns into a constant boost leak
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Sep 28, 2008 | 12:11 PM
skoloseven's Avatar
WOw.. your car is a beast if it's popping that thing off ~!
So what would the gains be to this other than your obvious one?? Is there actually HP gains or loss??
How does the fuel vapor play a roll? How much fuel vapor is actually being dumped? Is there enough to make a diference??
Also-- how does the ecu react to this and other CEL's?? Does it change mixtures to a default setting?? Or does it do a limp mode?
Old Sep 28, 2008 | 12:23 PM
blacksti's Avatar
DudeMan
no gains really except if it leaks like mine
its just emissions bs instead of venting the vapors out it sends them to the intake manifold.... i took mine off and dindt get any cells but some people say they get them... i put mine back on because the car ran funny with it off without being tuned
2jz mustang build
Old Sep 28, 2008 | 12:46 PM
3gsucks's Avatar
leave that on. unless your that maybe 5% that run over 20++ pounds of boost on bigger turbos
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Old Sep 28, 2008 | 01:40 PM
skoloseven's Avatar
So basically the only advantage to this is removing it because i have pressures caused by larger turbos--- my lil td04 doesn't make enough vacuum so there's really no need to do this, right??
Old Sep 28, 2008 | 01:43 PM
3gsucks's Avatar
correct
Old Sep 28, 2008 | 02:18 PM
skoloseven's Avatar
awesome! good thing I could glue the broken parts back together--- so does the lack of this cause the ecu to run rich, lean, or some kind of limp mode??
Well i reinstalled it and took it for a test drive, and the car runs much better now. There is no more hesitation, and the car runs much better. I had questioned if it was my cai, or a combo of both. It turns out, I think, that it was lack of a purge system.
It was like night and day. So morale of the story, don't do this unless your tuned and have too big of a turbo that pops hoses of this system. If you are tuned, from information gathered above, it gains no hp but does not affect performance either. If you are running un-tuned with this modification-- you are likely to see less performance and the car run like crap. Mine hesitated like it was stuck every 1000 rpms or so. really crappy
