helppp
helppp
so i blew a vacuum line of the cyl head put it back on now im not hitting full boost
it was 21.5 now im only hitting 15-16psi what could it be?
noooo i hope not
i doubt it cause it drives fine just doesnt hit targeted boost
wouldnt i have a lot more symptoms other then not hitting target boost... like i said before the cars running fine just not hitting targeted boost
now its hitting 18psi? wtf i thought maybe the heat had something to do with it but its been hot as fuck for the past month and nothing till the other day
Did a knock sensor trigger and your Advanced Multiplier drop? Try disconnecting the battery and take the car out, let it warm up to operating temp, put it in 4th at 2,000 rpms and step into it until you hit about 5,500 rpms. I had to do this a week ago. It worked great. Do you have AP II? The new flash allows you to see you Multiplier and watch it increase.
