Subaru Tech All We'll Drive
Proven 1/4 mile times!
Old Aug 28, 2011 | 09:31 AM
  #121 (permalink)
Tupass's Avatar
Only Bolt ons!!
Lol..Thanks bro
TampaBayTunedInc.
Area51Tuned
Old Aug 28, 2011 | 09:55 AM
  #122 (permalink)
jcssti6265's Avatar
TampaBayTunedPerformance
Originally Posted by javasti
not proud of my times (spinning and bogging), but I did trap 93 mph..
Yeah, you need some track time, we need to go on a wednesday and play with the launch and i could hear your blow off valve between shifts, that tells me your lifting when you shift. u will grab another 4-5mph easy without lifting. With the power that car makes, when you get the kinks in the driving worked out and tires you should be well over 100mph and in the 6 second range.
Old Aug 29, 2011 | 02:25 AM
  #123 (permalink)
Tampabaytunedinc's Avatar
Originally Posted by psi_R170
previous owner had a manual boost controler. but he removed it and never put the restrictor back in the vac line, but im scared to just throw that on there w/o being ready for a tune.
Stock turbo? Dont be scarred, if its stock turbo u dont need a tune for anything under 20psi. Just watch ur afr.
Old Aug 29, 2011 | 06:40 AM
  #124 (permalink)
psi_R170's Avatar
Better known BrownMK3Kid
alright will do. thanks man. anything to be worried about with timing and knocking? or does the computer take care of that itself? and stock boost is like 16psi correct?
Old Aug 29, 2011 | 09:49 AM
  #125 (permalink)
stock boost is around 14-15, appr 1 bar. i would not pass 18psi without an adjustable fuel regulator. if you have on 20 is fine, ecm will shut you down past that. and it will retard the timing if you start to knock. You will be fine till your tune.
Old Aug 29, 2011 | 11:12 AM
  #126 (permalink)
psi_R170's Avatar
^alright thank you. will try this out soon
Old Aug 29, 2011 | 12:02 PM
  #127 (permalink)
go for it, you should be running under 8.5 and over 80mph
Old Jan 20, 2012 | 04:39 AM
  #128 (permalink)
jcssti6265's Avatar
For anyone who wants to see my TBT STi defend its grab-a-lane KOTS(king of the street) #2 spot against a very fast pontiac, it will be at bradenton on the 26th. Subaru Power FTW!!! come support us.
Old Jan 21, 2012 | 06:50 AM
  #129 (permalink)
Tupass's Avatar
Only Bolt ons!!
woot woot
TampaBayTunedInc.
Area51Tuned
Old Jan 23, 2012 | 04:13 AM
  #130 (permalink)
TPNORTH's Avatar
i saw some vids of that pontiac that bitch is fast but i still have my money on the suby and driver mod! Did you run it yesterday at IFO james? I saw the times for the street evo that were pretty sick.
