Best Ways to Eliminate Heat Soak/Prep for BMP
Classy STI Driver
on
Thinking ahead to the BMP meet/track event tomorrow, I remembered the last time I was at the track was during the same time of the year (mid-June actually). I need some advice on cooling my mostly-stock STI right before some runs. I will be driving from Sarasota directly after work, so the a/c will have been blasting for close to 30 mins by the time I arrive. Mods are in sig...
Andrew's 2007 UGM STi Limited #433
Defi Red Racer Boost + Oil Pressure | Innovate WB A/F | V1 radar | Cobb AP protune | Spearco TMIC | APS 3" catted TBE | APS CAI | APS turbo inlet | DeatschWerks 750cc injectors| Walbro FP | Beatrush forged pitching stopper | Kartboy hangers |Coolant bypass | Prodrive EBCS | Debadged trunk | Cobb heatshield |DRL delete | Autospeed dead pedal + black license plate trim | Primitive Armor |
284whp/307wtq (mustang dyno)
they sell bags of ice at the track. set them on top of your IC.
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
heat wrap, turbo wrap, ice on intercooler, can spray n2o or co2 on the intercooler, alcohol in the sprayer tank, turbo heatshield
can do alot of things.
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
we redirected your TB coolant, which helps... Other than that, keep your hood up until you're actually going to run, blast it with water as soon as we get to Chris' house, keep ice on the I/C, etc...
I would insulate your I/C for you a little bit more if we had time
Classy STI Driver
on
Definitely going to look into ice once I actually get the BMP, possibly to put in the I/C water spray reservoir. I will have my hood up too, once I get to Chris's.
On second thought, maybe I'll install a 2nd battery and connect it to an electric space heater. After all, STI's run notoriously cold and must be kept warm to run at their best.
