Another rear diff question! HOMEMADE, help!
yeah, you would have to drill if you don't have an r180 flange or an autoshaft. I'd trade you as I have an R180 (reflanged) and an automatic's shaft...
If drilling be spot-on and dead center or else you'll have a "wonderful" vibration.
also, as far as I know your 06 axles shouldn't have a problem with on 02 wrx rear diff (assuming its a re-geared wrx rear end).
"Racing is life. Anything before or after is just waiting." -Steve McQueen
http://www.timeattackforums.com/foru...referrerid=218
well, cost of machine time vs. shipping shafts...the shaft swap may actually be cheaper
that and then nothing is ghetto rigged either!
Check your local junkyards for any automatic impreza. The driveshaft will be exactly what you need.
Either that or I should be taking a trip on down to tampa in 3 weeks...should
the holes don't need to be bigger...its a bigger pattern.
think of the difference between a 4x100 and a 4x114.3 lug pattern
