Subaru Tech All We'll Drive
Got a CEL...
Old May 6, 2008 | 03:52 PM
flystiguy01's Avatar
Skunk.
theres basically a checklist of things that your car checks for while it is running.. any tuner has the capability to uncheck the one that is showing up.
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
Old May 6, 2008 | 03:53 PM
Wrxgurl06's Avatar
Ok, I gotcha.
-2006 Subaru WRX Limited
-2009 Chevrolet Cobalt SS
Old May 6, 2008 | 04:07 PM
WTFchuck's Avatar
oh WTF
Originally Posted by 13Brotary
That's for the dp 02 sensor. You can do either a mechanical fix or electrical. The mechanical involves using two spark plug extensions and screwing them into the exhaust pipe and the 02 sensor into the end of the extensions. The electrical fix uses a resistor in the 02 sensor cable. Both are really easy and cheap, or you could just tune it out.
that might throw off there afr's since they were tuned that way
2011 Mustang GT 5.0
Sterling Grey Metallic
401a, comfort pkg, electronics pkg, security pkg, 3.73 gears
Orderd Sept. 29th, Built Nov. 8th, Delivered Nov 18th!!!
Old May 6, 2008 | 05:04 PM
13Brotary's Avatar
The AP gets rid of the CEL (tunes it out) so that's probably why it didn't show up. If you have a Tactrix and laptop you can get rid of it yourself.
Old May 6, 2008 | 05:13 PM
Wrxgurl06's Avatar
That's what I figured. But I don't have the cable to do it myself.
Old May 6, 2008 | 05:35 PM
cheesetits's Avatar
Cant you use the AP cable to do it yourself? Ive been using it to datalog for a couple of years. Or is it just able to datalog and not tune with?
Old May 6, 2008 | 06:55 PM
  #17 (permalink)
Wrxgurl06's Avatar
I'm not sure, plus even if I could I don't know what to look for...lol
Old May 6, 2008 | 09:33 PM
  #18 (permalink)
LDadrenaline's Avatar
yeah, I drive a miata
yes you can check and clear codes with the accessport
i cant believe gadiel would forget something like telling the ecu to ignore that code. thats like tuning subarus 101. first thing is have it ignore the O2 codes.
reason you didnt get it before is that all accessport maps are programmed to ignore it.
[/center]
Old May 7, 2008 | 06:45 AM
  #19 (permalink)
Wrxgurl06's Avatar
Oh, yeah I already cleared the code with the AP. I thought the other guy meant turn of the light with the AP.
Old May 7, 2008 | 07:40 AM
  #20 (permalink)
cheesetits's Avatar
A little off topic but what did you pull on that dyno Wrxgurl? I was able to get 275/280 with my stg 2+ sti with a conservative 17-18 psi tune and 305/319 on an agressive 20-21psi tune.
