Subaru Tech All We'll Drive
tuning question
Old Mar 23, 2008 | 10:09 PM
05sti's Avatar
Default tuning question
Mainly for Snowman, but all posts are appreciated. i had a snowman tune for 3in tbe, 255 fp and 19 psi tune. i was wondering if i went back to stock exhaust how much will it hurt my engine with this tune? i recently moved to va and might be considering an exhuast change for emissions. thanks
Old Mar 24, 2008 | 12:36 PM
3gsucks's Avatar
put the stock exhaust on only to pass emission test then put it back on after.
you cant run 19psi on the stock downpipe with the cats in place its too restrictive and will cause the egts to go up and cause the car to knock.
you should be able to drive the car around with out a problem enough to get the emissions test but as for going into boost its probably going to start breaking up.
im pretty sure Jeff is going to say something similar
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Old Mar 24, 2008 | 02:30 PM
1BDREX's Avatar
yeah itll be ok to drive around aslong as u dont go into boost. although it wont even let u boost 19psi. is too much restriction for ur tune. like 3gsucks said, just put it on for inspection and take it back out.
99 Prelude SH-slow but sooo SEXY
04 WRX-300WHP silver bullet
09 Si SEDAN UNDER CONSTRUCTION
Old Mar 24, 2008 | 07:53 PM
SnowMann's Avatar
TR Shop Mod
VA huh? I hear theyre pretty strict when it comes to any mods. Yeah they both hit it on the head. Id put it on for the test, then maybe look into a stock catback for stealth when it comes to the LEO's
SnowMan tuning
Old Mar 25, 2008 | 08:31 AM
05sti's Avatar
yeah. i had the stealth but was told that all components need to be stock. va sucks for tuner cars. thanks for the input.
