Subaru Tech All We'll Drive
CEL P0442 help please...
Old Feb 19, 2008 | 04:12 PM
randysti's Avatar
Default CEL P0442 help please...
this cel comes on and off periodically when im drving mostly on the freeway and goes off in about three or four days, unless i disconnect my battery,
do any of you guys have this problem
OBD-II Trouble Code: P0442 Evaporative Emission Control System Leak Detected (small leak)
its tell all in the link but still will it cause any problems in the long run do you know ???
and also where in the sti is the evap system ???
2008 Lexus ISF
2007 Aprilia RSV 1000R > Leo Vince full
Old Feb 19, 2008 | 04:17 PM
blacksti's Avatar
DudeMan
did you make sure your cap is tight?
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Feb 19, 2008 | 05:58 PM
randysti's Avatar
yep yep
2008 Lexus ISF
Old Feb 19, 2008 | 06:52 PM
1BDREX's Avatar
did u upgrade ur fuel pump? cause it could be the gasket or the seal on the fuel pump plate on the tank
99 Prelude SH-slow but sooo SEXY
04 WRX-300WHP silver bullet
09 Si SEDAN UNDER CONSTRUCTION
Old Feb 19, 2008 | 07:54 PM
randysti's Avatar
fuel pump is still stock cant find where the problem is
2008 Lexus ISF
Old Feb 20, 2008 | 07:28 AM
BadgrlSTi's Avatar
Just from reading the link...was wondering if you tried turning your gas cap at least 3 x's after filling....i threw a CEL once after filling up, reset the battery and screwed the cap at least 3x's and never threw a cel again. It may sound stupid, but i've had probs with a diff. car and those gas cap censors.
Old Feb 20, 2008 | 09:15 AM
I'm Slow's Avatar
I'm Slow
I had this problem on my WRX forever. It is a small emissions leak. It seemed to mainly come on when I was cruising on the highway. I noticed it once I changed my coolant to turbo hose because the stock one melted on my big tmic. After getting the cel......then it turns off by itself........then comes back......then back off and back on....etc. I replaced the hose with another stock one and never got the cell again. This cell is probably one of the hardest to detect where it's coming from. Have you replaced any lines,hoses, or sensors on the car? What mods have you done? good luck.
