springs
are the cobb sport springs any good?
STi & WRX Performance Parts: COBB Sport Springs, 2004+ Impreza
i was looking at those and the tein s. tech's what do you guys think?
yes they are good, but there are better springs. I would suggest crucial springs first, they are almost identical to the STI pinks (considered the best springs for stock struts) but are considerably cheaper. After those I would suggest prodrives.
[/center]
[/center]
if you do more of a drop you run into problems. they will probably rub a little. but the biggest problem is that you will prematurely wear out your struts. anything lower than crucial/sti pink/prodrive kind of spring lowers past the efficiency range of the stock strut and overworks it, causing it to blow out much more quickly
[/center]
[/center]
I thought u wanted to go with coilovers?
Im running H&R Race springs on stock struts. They've been on there for 50K miles and the struts are still in good shape. Heres a pic of the car on 18" wheels.
please don't get tein s techs they are really really bad, with your struts and performance, also their too damn stiff I know cause I used to have them, now it does make the car look hella good but I wouldnt recomend them.
