alarm problems
i know buzz off carries viper alarms, they can probably help you out.
Buzz Off Alarms Stereos Tint - Tampa, FL 33614 - Reviews: Car Radios Repair and Installation, Audio-Visual Equipment, Security Systems
Jon is a good guy over there if you want someone specific to talk to.
[/center]
[/center]
-2006 Subaru WRX Limited
-2009 Chevrolet Cobalt SS
yeah but i think he wants the remote so he can disarm the system. doesn't it disable the car while the alarm is going off? I assume any alarm worth its money would have a redundancy system set in place so that you can't simply open the car while the alarm is going off and unplug it.... just seems too easy to me, but then again I tend to over-complicate things
hey I've done alot of work on the viper systems at my last jobs, I used to do professionall car audio intallations. If you need help, or if you need help taking it out give me a call Nick. And you cant just rip it out if the used the viper starte kill, because the hade to cut the starter wire, so you would have to reconnect that. IT all depends alot of people hook them up differently so with out looking at it personally I couldn't tell how its hooked up. Give me a call if you have any questions or need any help Nick 727-249-3114
I know with the viper I had valet mode was easy to do. You open the driver door, then on the key fob do "lock, unlock, lock" and you should be good to go. Then when you're done, do the same thing over again.
