Subaru Tech All We'll Drive
Hub questions
Old Nov 8, 2007 | 06:38 PM
FlybyTT's Avatar
Default Hub questions
since a svx is 5x114.3 and ppl dont really know or consider it could you use ther hubs to get the brembo's etc
the axles etc what rear end do they have
sry for the off track questions but svx parts are alot cheaper becuase of peoples knowledge of them is shall i say limited
JDM STI V8 EJ207 - STI JDM 6 Spd spec c ra transmission - cusco rear lsd - catless turboback exhuast - IHI VF37 turbo - Walbro 255 fuel pump - HID lights - exedy clutch/flywheel
One Man's Trash Is Another Man's Treasure. (srqsti)
Working on the 3000GT VR4 in working order kinda...
Old Nov 8, 2007 | 10:01 PM
LDadrenaline's Avatar
yeah, I drive a miata
im sure the mounting point for the brake caliper is different seeing as the years are so far off. no idea though, maybe it will work.
[/center]
Old Nov 9, 2007 | 10:16 AM
WhiteGhost2.5's Avatar
WOMBAT Racing
The hubs will not swap into the Imprezas. The Rear hub trailing arm mounting point is at a different angle on the SVX. The SVX front hub ball joint is completely different as well. I looked into this awhile ago. Thats good tho think outside the box.
Josh
