Subaru Tech All We'll Drive
LSD Questions
Old Oct 30, 2007 | 07:12 AM
FlybyTT's Avatar
Default LSD Questions
does anyone have the none dccd 6spd i have lots of question for you if you do. Also does anyone have a different rear lsd i have questions for you aswell thanks in advanced
JDM STI V8 EJ207 - STI JDM 6 Spd spec c ra transmission - cusco rear lsd - catless turboback exhuast - IHI VF37 turbo - Walbro 255 fuel pump - HID lights - exedy clutch/flywheel
One Man's Trash Is Another Man's Treasure. (srqsti)
Working on the 3000GT VR4 in working order kinda...
Old Oct 30, 2007 | 08:14 AM
homemade wrx's Avatar
start asking your questions...
also which non dccd 6-spd are you asking about in particular?...referring to the entire drivetrain?
Old Oct 30, 2007 | 08:19 AM
FlybyTT's Avatar
i knew youd be the guy to answer my question and all i can say is ty ty ty
well do u have the click click click noise of an over aggressive lsd i have the 1.5 cusco..
and i have the ra spec c with the suretrac front lsd
Old Oct 30, 2007 | 12:29 PM
I've driven two cusco equipped drivetrains and both were r160 rears...both were set agressively and both clicked and scrubbed tires...they are also the only diff's I've driven that clicked (metallic clicking from the plates)
my factory r180 is pretty agressive as well out of the box and would rather scrub my 235's than slip on tighter turns...my spare r180 I haven't driven yet.
I have the suretrack front lsd in my current 6-spd as well but its quiet and doesn't scrub (as it shouldn't).
can you elaborate on your clicking noise and when/how it happens?...may be something else.
Old Oct 30, 2007 | 01:03 PM
FlybyTT's Avatar
im just making sure the cusco click is normal my new "problem" is that my car all of a sudden has started pulling to the left and everyonce and a while ill get a creaky noise from up front. i have yet to put my finger on it but ima lift it this weekend and check boots out etc
Old Oct 30, 2007 | 02:37 PM
if it pulls one way or another randomly...it sounds like possibly a tie rod or a wheelbearing going bad...
jack up the front of the car and wobble the wheels in and out both by placing the force on the sidewalls on left and right side and then top and bottom.
if you have play/slop in all directions its most likely wheel bearing...if only with hands on left and right of the wheel...its most likely tie rod...if only top and bottom, ball joints or loose strut tower bolts.
are you using any additive for the rear lsd?
Old Oct 30, 2007 | 04:37 PM
FlybyTT's Avatar
no i didnt get any syrups for the lsd but i would like to make one... i mean cocktails
Old Oct 30, 2007 | 04:47 PM
trans-x posi trac is good and so is the BG special order stuff I have...they work about the same though...
Start by putting in a tiny amount. Don't follow the directions!!! they are for putting into a large domestic pumkin...follow the directions and you'll eat your diff.
It helps keep the plates from having that sticking effect that you notice on turn in.
Old Oct 30, 2007 | 04:51 PM
FlybyTT's Avatar
can u pm your number and a date i can take u on a ride and you can tell me what you think so far
Old Oct 30, 2007 | 09:15 PM
I'd love to but next time I'll be down there will be in december for house hunting, so if you're patient
