Subaru Tech All We'll Drive
How To:Boost Gauge Brass T Fitting
Old 10-20-2007, 06:37 PM
rex'03's Avatar
Default How To:Boost Gauge Brass T Fitting
I thought I'd make this quick how-to on making a permanent fix to the T fitting connecting the vacuum/ capillary tubing going from the bypass valve to your boost gauge inside the car. My specific gauge that I have is an Auto meter 30 PSI Pro comp. I experienced failure with the plastic, and rubber connections associated from the Lamco /auto meter parts to connect everything together out of the box originally. It's pretty self explanatory with the part's, and how to put everything together. I now have no more boost loss, and everything runs as it should.
Place of purchase for parts: Home Depot, and Advance Auto Parts.
Process: The main part is the T block that puts everything together. I used two 1/4" barb fittings to connect the by pass valve vacuum hose securely to the T block. On the third port I used an adapter, and a compression fitting with Ferrel to secure the capillary tubing connecting the line going to my boost gauge. Please refer to the pictures for a part's listing, and pictures of the completed project. The time this project took me was forty minutes..
EDIT: Make sure you use Teflon tape, or Teflon sealant to ensure you have a good, tight seal on your item's being assembled.
Eric
'03 WRX 5-speed OBP (APS TBE, and Prodrive)
Snowmann Tune- 18 pounds
Old 10-20-2007, 08:05 PM
DudeMan
blacksti's Avatar
thats sweet but you could have went through a lot less trouble
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old 10-20-2007, 09:08 PM
rex'03's Avatar
Old 10-20-2007, 09:13 PM
What the fuck is this?
gringoplaya's Avatar
My car came with one stock lol.
but good write up
gimme becky I can't sleep
Old 10-21-2007, 09:34 AM
aka EJ20T
TYJaMO's Avatar
Home Depot DIY FTW!!!
