Yay...
cant do a 6mt, something about the 06 rear end is different. you have to change all the drivetrain pieces including the axles (which are attached to the hubs and since its off an sti that would mean 5x114.3). Both sets of wheels I have are 5x100, and I have a $3000 BBK that fits a wrx, not an sti. wanted to just swap in the 6spd and call it a day, but alas, its not that easy
It really is that easy...easier for you than me, as I had to change 2 studs on the diff and go to the newer age tranny crossmember
as for other gearset optionss...
hollinger (mrt and awesome!!), par/chalak (commone manufacturying related failures), kaaz (seem to eat 3rd gears in the syncro sets also short!!!), modena(early mrt) and aps (crappy)...just to name a few
as for 1.5 hours to pull the tranny, damn!!! you have me beat my 15 minutes
I'm serious...as the dyno shop I use to work at, I was the subaru tech and have pulled my own trannies (I have 3 that I alternate
) 12 times in the past 6 months...slight power issue...also have done 3 rear diffs in that time.
the 6-spd there is now way in hell I could do in that time...it is such a tight fit that it actually touches both sides of the tunnel.
Now, the 1.75 hours job was a cable-clutch, push style.
) 12 times in the past 6 months...slight power issue...also have done 3 rear diffs in that time.the 6-spd there is now way in hell I could do in that time...it is such a tight fit that it actually touches both sides of the tunnel.
so out of the gearboxes/sets you named the only one worth getting (the hollinger) is more expensive than the ppgs? damn
[/center]
[/center]
takes money to play the game my friend you got into a bad hobby if you dont like spending money
are challacks supposed to be as good as PPGs? will they at least be bulletproof at 300whp?
[/center]
[/center]
not to long ago I got rid of my par straight cut dog box for fear of destroying them...that and gerard said they wouldn't hold my end goal
modena's are nice and are on the roger clark motorsports "gobstopper" but a 6-spd set. Shawn Lozy still has a set in his car that made 600 but has been sitting for the past 2 years...hollingers are quite nice and are slide on, not press on...andy forest is actually running them in his 9.1 second scoobie.
ppg's are a great bang for the buck...the 5-spd dog box can only handle 800...if you want more than that, you need a built 6-spd
When your running on a track everyother weekend your going to wear parts even faster and you'll find the weakness of the vehicle real fast!Running tracks are great just make sure you got the money to back it up.NOT JUST TALKING TO LD.....lol
