Subaru Tech All We'll Drive
engine help
Old Oct 5, 2007 | 09:45 PM
boostnwrx's Avatar
Exclamation engine help
i have a 03 wrx ok my question his i blew a rod what can i do now thats not going to break me i would like to get it running soon i herd alot of ppl doing a 2.5 short block but then i herd the wiring is so hard to do its not even worth it the i herd about forged pistions and rods for a good price help anyone
Old Oct 5, 2007 | 10:18 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
How'd you manage to blow a rod?
-Winston Churchill
Old Oct 6, 2007 | 09:47 AM
im2wrxy's Avatar
I would just buy a 2.5 short block (I got mine w/14K miles for $1100) and use your wrx head...no wiring changes needed. Everything will fit on the 2.5 block. You'll need a gasket kit including head gaskets, and all the fluids. I have no idea how much it would cost to have it swapped out; I did mine myself, but I would imagine you could do it for ~$2K if you bought the parts and had someone install it.
While I was at it I swapped the clutch, flywheel, crank pulley, motor mounts, oil pump, timing belt, water pump, and accessory belts because it's alot easier to do it when the motors out and I had almost 70K miles on it anyway. So, obviously any extra parts that you decide to change (some I would highly recommend depending on how many miles on the car) will cost you extra. My whole swap (parts above plus a few others) cost me $5K and I only paid $500 to someone else to have the head reconditioned, the block inspected/honed, etc. The rest was the cost of the parts.
It's very difficult to do it right and cheap at the same time whether you go with a 2.5 or a 2.0 IMHO.
Old Oct 6, 2007 | 12:44 PM
ryan_west06's Avatar
what is done to your car! how much boost?
Old Oct 6, 2007 | 09:30 PM
boostnwrx's Avatar
i was racing i no dumb ideal. 2nd question i have full exhaust nothing real major want to upgrade turbo and ecu later on
Old Oct 8, 2007 | 04:08 AM
RAYC4G63's Avatar
All you need is a set of cometic gaskets,ARP head studs and a 2.5 short block.Everything else is the same the only THING YOU HAVE TO DO IS THE STI HAS A VENT ON THE BLOCK JUST TIE IT INTO THE VALVE COVER GASKET VENT HOSES AND YOUR ALL GOOD....maybe follow by a good tune.
Old Oct 8, 2007 | 05:45 AM
im2wrxy's Avatar
Or you can just plug it like I did.
Old Oct 8, 2007 | 08:12 PM
boostnwrx's Avatar
thanks for all your help looks like im now looking for a 2.5 block
Old Oct 9, 2007 | 05:50 PM
homemade wrx's Avatar
I get my EJ257 shortblocks for cheap...PM me if you want a price quote on a new one.
Old Oct 9, 2007 | 06:55 PM
LDadrenaline's Avatar
yeah, I drive a miata
gruppe-s has them pretty cheap i think. the jdm forrester engine is the same thing as the usdm sti engine
