Subaru Tech All We'll Drive
CEL Cylinder 1 lean
Old Sep 21, 2007 | 03:35 PM
02'subie dude's Avatar
Default CEL Cylinder 1 lean
Like the title says, my car is running lean on cylinder 1. I am also getting pre-detination (I can hear the valves clatter under full throttle, even in second!) I am basically just stage 2 with cobb map, exhaust and uppipe.
When I accelerate, not even full throttle the power is not there, and at 4k it seems to just fall on its face. When I reset the ecu, the car ran fine. I have been doing alot more highway traveling lately, and see 80+mph daily. I am running 10w-40.
Is it possibly because I dont have a intercooler diffuser, and am putting the car under to much of a load at to low of an RPM? Maybe the 93oct here in TX compared to FL, is SH*T.
I could really use some suggestions. THANKS
<img src=https://www.tamparacing.com/forums/signaturepics/sigpic42730_1.gif alt= class=post_inline_image loading=lazy />
Old Sep 21, 2007 | 03:46 PM
JonLGT's Avatar
Just for decoration
Make sure you have plenty of oil, that valve tap might be more than you think.
Old Sep 21, 2007 | 04:13 PM
Damn thats what I was afraid of. I just changed my oil. Used the good stuff. I was going to go with 10w-60...
Old Sep 21, 2007 | 05:29 PM
JonLGT's Avatar
Just for decoration
Ever notice if it was low? 1 qt makes a hell of a difference, especially on an older car which probably burns a bit of oil.
Old Sep 21, 2007 | 06:26 PM
I did notice that the oil was low on my drive from Florida to Texas, but I filled it up and that was a month ago. The car now has 75k/mi on it. Hopefully, it will remedy itself??
Old Sep 21, 2007 | 10:04 PM
ryan_west06's Avatar
I wouldnt run the car if your cyl 1 is running lean. Id run some lucas cleaner thru it. chage your oil to 5W-30 and see how that works out.
when you change the oil, put some oil cleaner in the car first. let her run for about 5-10 min then change the oil. That will get all the old junk out.
Old Sep 22, 2007 | 07:52 AM
^Thanks man, ill give it a shot. Either that or 1)trade it in 2)blow it up
Old Sep 22, 2007 | 08:46 AM
JonLGT's Avatar
Just for decoration
Option one sounds better.
