Awesome!
So its finally over guys, car is running!!! Everything seems fine.... no CEL....
but i still have a little problem with the clutch... The pedal is pressed really close to the floor. it has enough pressure to engage the clutch but its so short. Ive stalled the car a couple of times
I did bleed the line.... but it still wants to sit close to the floor. Any ideas guys???
.I did bleed the line.... but it still wants to sit close to the floor. Any ideas guys???
hey guys! can anyone point me in the right direction on how to adjust the clutch pedal to make it a little higher.... its WAY to low. i know i just put this clutch on and it should be breaking in but i feel like i keep burning it up while taking off from a red light or a stop. i can smell it!!!!!
its running so strong.... still kinda breaking in the clutch.
ive droped it a couple times and it launches so quick.....
probably the biggest gain ive seen on a bolt on it my 9lb flywheel
new clutch, new flywheel....ppg tranny!
but now i ran into a problem tonight guys! while leaving school i shifted into 2nd gave it some gas and pop, sounded like something blew off. car starts to sputter then starts to stall. I pull over and it dies. Im like WTF!
Pop the hood, after looking around for 10 min i see nothing wrong. The i notice my profec b solinod turbo line has a gash in it.
i fix that and have AAA tow it home. Get home and try to start it.... it keeps puttering. I call jeff all stressed out. He tells me to check a couple of things. they end up being good. The only thing we can think of is its flooded with fuel maybe a head gasket. Hooked up the actron and it says all 4 cycl are missfiring. black smoke coming out the exhaust. i started it one time and it idled REALLY rough....
what do you guys think?
