Open downpipe
Me too if you help me i'll help you its easy? What you say
Scooby05
05 Subaru WRX!
rep for the avatar if ya like booty & Rum
Scooby05
05 Subaru WRX!
my car has a cutout and when the cutout is open it has alot more torque and boost alot faster.
when my O2 sensor was after the cutout and getting bypassed it popped alot but not so much now.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Mine just pops.Even with the midpipe connected and everything torqued down correctly it still pops.I need a new exhaust gasket.
-Winston Churchill
-Winston Churchill
Incorrect. Backpressure should be minimized as much as possible post turbo. May car trapped a consistent .5-1 mph higher running open vs. full TBE. Same exact mods on the car, comparable conditions.
I always thought it should be minimized on a turbo vehicle because it would impede the flow of the exhaust gases out the hot side.
-Winston Churchill
-Winston Churchill
Thank you schoellnasty and Matt for posting that so I don't have to rip into a n00b
Warning:
content ahead
On a turbo car, you ideally want ZERO back pressure after the turbo. The turbo itself works on the pressure differential between the inlet the outlet to operate. The turbo's resistance in the exhaust stream will provide the back pressure that the engine needs. Running an open downpipe will not increase your overall boost, but it will make the car slightly faster because it will spool up quicker. Of course, this means nothing if your ECU tune can't take advantage of it.
Warning:
content aheadOn a turbo car, you ideally want ZERO back pressure after the turbo. The turbo itself works on the pressure differential between the inlet the outlet to operate. The turbo's resistance in the exhaust stream will provide the back pressure that the engine needs. Running an open downpipe will not increase your overall boost, but it will make the car slightly faster because it will spool up quicker. Of course, this means nothing if your ECU tune can't take advantage of it.
So then downpipe isnt that bad. I wanna put my mid pipe on anyone wanna help I know how to but need tools thats all
Scooby05
05 Subaru WRX!
Scooby05
05 Subaru WRX!
hey just to let you know that that DP is not a bellmouth
"Light travels faster than stupidity. This is why some people appear to be smart until they open their mouths."
