Subaru Tech All We'll Drive
Problem with car need help asap!
Old Jun 2, 2007 | 09:46 AM
blacksleeper's Avatar
Giggity Giggity Gone
Exclamation Problem with car need help asap!
So I was driving my car today while it was raining and every time I accelerated past 8-10 psi of boost my car would suddenly bog and throw you forward. I have never had it do this before and am worried something is wrong. I currently have a vf30 on a fmic setup with supporting mods. The funny thing is the car ran great yesterday and then today it ran like shit. Idle and slow acceleration are fine, but once I punch it, within seconds the car will bog out. I have checked all over for boost leaks, fuel leaks, etc. and can't find anything. If someone has ever had this happen or knows what could be wrong please help. Thanks.
Old Jun 2, 2007 | 10:13 AM
From what Ive researched it sounds like the egt. Does that sound right cause I forgot to mention my car has no check engine light?
Old Jun 2, 2007 | 10:31 AM
I'm Slow's Avatar
I'm Slow
sounds like a coupler may have ripped or came off. Sounds like the car is just going rich due to a boost leak
Old Jun 2, 2007 | 10:35 AM
stealthc9's Avatar
sounds about right check all ur ic piping couplers or ur bov gasket
Originally Posted by Lime_Green_Hatch
i carry a gun because so many other losers and wanna be gangsters do.
Originally Posted by JH26
Morty,
The fact that I have red hair and no soul makes me very angry. I just wanted to let you know that when I swear and sling insults at you, its really because deep down inside, I hate myself. Please buy me some hair dye for my birthday.
Old Jun 2, 2007 | 11:11 AM
Siegel Racing's Avatar
TR Shop Mod
I agree, likely a high-boost pressure leak.
SS
Scott
Forged Performance
www.forgedperformance.com
770-792-0202
Siegel Racing
404-388-8751
www.siegelracing.com
Driver / Engineer / Tuner / Instructor
Old Jun 2, 2007 | 07:27 PM
ryan_west06's Avatar
my car was doing kinda the same thing! come to find out my damn TGV motor broke! was kinda my fault... but check them just to be sure!!
but kyle hooked me up with one of his and havent had a problem since!
Old Jun 2, 2007 | 07:35 PM
KAX's Avatar
KAX
my car ran funny all day today, same kinda thing, bucking and chugging idle sometimes. hopefully it works out tomorrow when I get it tuned, but it was running like a champ yesterday. . .
need to get rid of those damn tgv CELs so I know if something is actually wrong.
Old Jun 3, 2007 | 01:01 AM
SnowMann's Avatar
TR Shop Mod
Did you ever check the knock sensor like I mentioned? If it is loose it will think there is knock and pull timing something fierce and act just like that? I also seem to remember your car blowing the line off the BPV when we were tuning. Did you double check everything leading up to it?
SnowMan tuning
Old Jun 3, 2007 | 06:30 AM
ok so I double checked everything, no leaks and no loose sensors.....come to find out it is my oem egt sensor. I read on several other forums that the egt sensor will get too hot or read too high a voltage and send the car into limp mode. I remembered that we turned off the cel for the egt which is why it wasn't coming up on the dash. Once I reset the ecu and went for a drive the car was back to normal. So next thing to do is buy a bolt to plug in there and resistor the sensor. I had a feeling that was it but wanted to make sure it wasn't something else.
Snowman- sorry for waking you up yesterday, but I appreciate you trying to help me out and calm me down.
So does anyone know what size bolt goes in the up pipe to plug the egt?
Old Jun 4, 2007 | 10:47 AM
Alizarin's Avatar
Gravel fiend
From what I can tell, it looks like it'll be an M12 1.25 bolt. Get it in the highest grade stainless metal you can find. I would probably recommend no coating on it if possible (I have some high grade stainless stuff that the coating flaked off on the rest of my exhaust).
Get a nut that will go on it, and if you can, check the length so it doesn't protrude into the exhaust stream. Use the nut to fasten it down at the required length (or just cut part of the threads off to length). Use some high temp thread locker if you have it. Maybe a crush-ring for extra sealing protection.
