Subaru Tech All We'll Drive
td04 boost press?
Old May 28, 2007 | 03:54 PM
sonicwrx's Avatar
Default td04 boost press?
sold the vf22 and went back to stock. I talked to s.s. he told me to leave the vf22 map and turn down the boost because i still have sti pinks. What psi can i run on the stock turbo?
Old May 28, 2007 | 04:30 PM
im2wrxy's Avatar
Aren't you getting rid of it? If so, just turn it down to like 10 and away it goes.
Old May 28, 2007 | 04:42 PM
sonicwrx's Avatar
tru, i tryd to hook up the stock boost sil. and the car only made around 9psi. im going to be driving the car for a few more months so thats not gona do. I atleast need it to get out of its own way.
Old May 28, 2007 | 06:14 PM
im2wrxy's Avatar
Did you have an aftermarket boost controller in it? Still have it? If you had an aftermarket boost controller and now you're back on the stock solenoid but still using the non OEM lines you may have to go back to the OEM lines with the pill in it to get it to boost past 9.
Old May 29, 2007 | 01:59 PM
sonicwrx's Avatar
i tryd that and it didnt work. does the utec have any control over the solenoid?
Old May 29, 2007 | 02:57 PM
im2wrxy's Avatar
Yes, I'm pretty sure it does. It's possible you have a bad solenoid. PM Imslow, he just had the same exact problem. He may be able to help.
Old May 29, 2007 | 03:03 PM
JonLGT's Avatar
Just for decoration
yes it does.
Old May 29, 2007 | 04:34 PM
sonicwrx's Avatar
o well crap! i put the stock hoses with the pill. could i have forgot something ?
Old May 29, 2007 | 04:41 PM
JonLGT's Avatar
Just for decoration
I would make sure the hose with the pill is going to the right place, like make sure you dont have the lines backwards or something.
Old May 29, 2007 | 04:54 PM
sonicwrx's Avatar
ya everything is right. can the utec turn off the stock solenoid
