engine lean?
are you on the stock turbo?
thx for the afr info.
yes
20psi at redline with a stock turbo its really bad are you sure its holding till redline? are you sure thats not your peak boost?
it is holding well for now.
im sure it can go higher but im not trying to do that.
dude thats not good at all specially without meth
Methamphetamine?
Methanol?
Methane?
Methanol?
Methane?
*just looked it up
damn thats $500.
does it run to same place as the water injectors?
damn thats $500.
dude honestly! it doesnt seem like you know that much about car tuning at all. Holding 20 psi to redline is BAD! i would recommend you not push it that much! With out meth you should be able to push it to 18lb without any worry. But you are still running lean...
Did you buy the car like this? If so i would be worried...
you should get a new tune!!!! yesterday!!!
according to my afr im running rich usually 13.1-9:1 or anywhere below 14.7:1
only time i have any probs being lean is when im using cruise control, but, whenever i check my numbers everything checks out fine.
no. i have ecutech monitor, it has a setting for user control but says its not available on this ecu.
can anyone reccommend places to go with good reputations for tuning?
